I’m using OpenHAB 2 with the Z-Wave plugin. I have a self-made temperature sensor that is in FLiRS mode. How can update the temperature value (i.e. wake up the device)? In the Z-Way server, for example, I can click on the time the temperature was last read and thereby update the temperature from the sensor.
FLiRS devices are treated just the same as any other device. If you want to update it, then you can use polling, although it’s not very nice and you’d be better to configure associations.
Thanks, however with this I get the following error message:
[ERROR] [ntime.internal.engine.ExecuteRuleJob] - Error during the execution of rule Update Temperature: An error occured during the script execution: The name ‘refresh’ cannot be resolved to an item or type.
Well, I didn’t write this and it really shouldn’t be there at all. As I said - it’s OH1 documentation. However, you are of course free to update the documentation as well
