- Platform information:
- Hardware: RaspBerry Pi 4 with 4GB
- OS: Raspbian 10 (buster)
- Java Runtime Environment:
openjdk 17.0.8 2023-07-18
OpenJDK Runtime Environment Zulu17.44+15-CA (build 17.0.8+7)
OpenJDK Server VM Zulu17.44+15-CA (build 17.0.8+7, mixed mode) - openHAB version: 4.0.1-1
- Issue of the topic: openHab starts, but the site does not show
Basically the status show this:
openhabian@openHABpi:~/.sdkman/bin $ sudo /bin/systemctl status openhab.service
● openhab.service - openHAB - empowering the smart home
Loaded: loaded (/lib/systemd/system/openhab.service; enabled; vendor preset: enabled)
Active: active (running) since Fri 2023-08-11 16:58:31 CEST; 17min ago
Docs: https://www.openhab.org/docs/
https://community.openhab.org
Main PID: 604 (java)
Tasks: 29 (limit: 3839)
Wether the dashboard on :8080 nor on :8443 is reachable.
The log tells me:
2023-08-11 16:58:52.480 [ERROR] [ternal.service.BootFeaturesInstaller] - Error installing boot features
org.apache.felix.resolver.reason.ReasonException: Unable to resolve root: missing requirement [root] osgi.identity; osgi.identity=openhab-runtime-ui; type=karaf.feature; version=“[4.0.1,4.0.1]”; filter:=“(&(osgi.identity=openhab-runtime-ui)(type=karaf.feature)(version>=4.0.1)(version<=4.0.1))” [caused by: Unable to resolve openhab-runtime-ui/4.0.1: missing requirement [openhab-runtime-ui/4.0.1] osgi.identity; osgi.identity=openhab-runtime-base; type=karaf.feature [caused by: Unable to resolve openhab-runtime-base/4.0.1: missing requirement [openhab-runtime-base/4.0.1] osgi.identity; osgi.identity=openhab-core-base; type=karaf.feature [caused by: Unable to resolve openhab-core-base/4.0.1: missing requirement [openhab-core-base/4.0.1] osgi.identity; osgi.identity=org.openhab.core.config.core; type=osgi.bundle; version=“[4.0.1,4.0.1]”; resolution:=mandatory [caused by: Unable to resolve org.openhab.core.config.core/4.0.1: missing requirement [org.openhab.core.config.core/4.0.1] osgi.wiring.package; filter:=“(&(osgi.wiring.package=org.openhab.core.common.registry)(version>=4.0.0)(!(version>=5.0.0)))” [caused by: Unable to resolve org.openhab.core/4.0.1: missing requirement [org.openhab.core/4.0.1] osgi.ee; filter:=“(&(osgi.ee=JavaSE)(version=17))”]]]]]
at org.apache.felix.resolver.Candidates$MissingRequirementError.toException(Candidates.java:1341) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.apache.felix.resolver.ResolverImpl.doResolve(ResolverImpl.java:433) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.apache.felix.resolver.ResolverImpl.resolve(ResolverImpl.java:420) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.apache.felix.resolver.ResolverImpl.resolve(ResolverImpl.java:374) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.apache.karaf.features.internal.region.SubsystemResolver.resolve(SubsystemResolver.java:256) ~[?:?]
at org.apache.karaf.features.internal.service.Deployer.deploy(Deployer.java:399) ~[?:?]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.doProvision(FeaturesServiceImpl.java:1069) ~[?:?]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.lambda$doProvisionInThread$13(FeaturesServiceImpl.java:1004) ~[?:?]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128) ~[?:?]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628) ~[?:?]
at java.lang.Thread.run(Thread.java:829) ~[?:?]
Caused by: org.apache.felix.resolver.reason.ReasonException: Unable to resolve openhab-runtime-ui/4.0.1: missing requirement [openhab-runtime-ui/4.0.1] osgi.identity; osgi.identity=openhab-runtime-base; type=karaf.feature [caused by: Unable to resolve openhab-runtime-base/4.0.1: missing requirement [openhab-runtime-base/4.0.1] osgi.identity; osgi.identity=openhab-core-base; type=karaf.feature [caused by: Unable to resolve openhab-core-base/4.0.1: missing requirement [openhab-core-base/4.0.1] osgi.identity; osgi.identity=org.openhab.core.config.core; type=osgi.bundle; version=“[4.0.1,4.0.1]”; resolution:=mandatory [caused by: Unable to resolve org.openhab.core.config.core/4.0.1: missing requirement [org.openhab.core.config.core/4.0.1] osgi.wiring.package; filter:=“(&(osgi.wiring.package=org.openhab.core.common.registry)(version>=4.0.0)(!(version>=5.0.0)))” [caused by: Unable to resolve org.openhab.core/4.0.1: missing requirement [org.openhab.core/4.0.1] osgi.ee; filter:=“(&(osgi.ee=JavaSE)(version=17))”]]]]
… 12 more
Caused by: org.apache.felix.resolver.reason.ReasonException: Unable to resolve openhab-runtime-base/4.0.1: missing requirement [openhab-runtime-base/4.0.1] osgi.identity; osgi.identity=openhab-core-base; type=karaf.feature [caused by: Unable to resolve openhab-core-base/4.0.1: missing requirement [openhab-core-base/4.0.1] osgi.identity; osgi.identity=org.openhab.core.config.core; type=osgi.bundle; version=“[4.0.1,4.0.1]”; resolution:=mandatory [caused by: Unable to resolve org.openhab.core.config.core/4.0.1: missing requirement [org.openhab.core.config.core/4.0.1] osgi.wiring.package; filter:=“(&(osgi.wiring.package=org.openhab.core.common.registry)(version>=4.0.0)(!(version>=5.0.0)))” [caused by: Unable to resolve org.openhab.core/4.0.1: missing requirement [org.openhab.core/4.0.1] osgi.ee; filter:=“(&(osgi.ee=JavaSE)(version=17))”]]]
… 12 more
Caused by: org.apache.felix.resolver.reason.ReasonException: Unable to resolve openhab-core-base/4.0.1: missing requirement [openhab-core-base/4.0.1] osgi.identity; osgi.identity=org.openhab.core.config.core; type=osgi.bundle; version=“[4.0.1,4.0.1]”; resolution:=mandatory [caused by: Unable to resolve org.openhab.core.config.core/4.0.1: missing requirement [org.openhab.core.config.core/4.0.1] osgi.wiring.package; filter:=“(&(osgi.wiring.package=org.openhab.core.common.registry)(version>=4.0.0)(!(version>=5.0.0)))” [caused by: Unable to resolve org.openhab.core/4.0.1: missing requirement [org.openhab.core/4.0.1] osgi.ee; filter:=“(&(osgi.ee=JavaSE)(version=17))”]]
… 12 more
Caused by: org.apache.felix.resolver.reason.ReasonException: Unable to resolve org.openhab.core.config.core/4.0.1: missing requirement [org.openhab.core.config.core/4.0.1] osgi.wiring.package; filter:=“(&(osgi.wiring.package=org.openhab.core.common.registry)(version>=4.0.0)(!(version>=5.0.0)))” [caused by: Unable to resolve org.openhab.core/4.0.1: missing requirement [org.openhab.core/4.0.1] osgi.ee; filter:=“(&(osgi.ee=JavaSE)(version=17))”]
… 12 more
Caused by: org.apache.felix.resolver.reason.ReasonException: Unable to resolve org.openhab.core/4.0.1: missing requirement [org.openhab.core/4.0.1] osgi.ee; filter:=“(&(osgi.ee=JavaSE)(version=17))”
For me it looks like something was updadet, but i miss a lot of parts. I did the update to java 17 manually and now i’m lost. Any help?
