Platform information:
- Hardware: Synology Drive
- OS: Synology DSM OS
- Java Runtime Environment: 8.0.212-818
- openHAB version: 2.5.2.000
- Issue of the topic: Bridge & Thing (Lamp) Showing, Items Not Working
Note: Everything being done via text editor, no PaperUI config.
I have successfully gotten my Hue Bridge via .things file:
Bridge hue:bridge:mybridge [ ipAddress=“192.168.x.xxx”, userName=“RVkZfmEpuBsaerhhfdbLXmadsff5jadfHMCqadfHV5gsfqrK0TUwy4jkB1Q”, pollingInterval=“2” ] {
0210 bulb1 “Bhavani’s Nightstand” @ “Master Bedroom” [ lightId=“1” ]
And have edited a .items file:
// Bhavani’s NIghtstand
Switch BhavaniNightStand_Toggle { channel=“hue:0210:1:bulb7:color” }
Result: Switch appears in Paper UI “Control” screen.
I update .items file:
// Bhavani’s Nightstand
Switch BhavaniNightStand_Toggle { channel=“hue:0210:1:bulb1:color” }
Dimmer BhavaniNightStand_Dimmer { channel=“hue:0210:1:bulb1:color” }
Color Light1_Color { channel=“hue:0210:1:bulb1:color” }
Dimmer Light1_ColorTemp { channel=“hue:0210:1:bulb1:color_temperature” }
Result: I still only see the Switch.
I updated .items again:
Result: Dimmer, color, and temperature controls appear
Question: Is it not possible to have a switch & the other controls ? I’d like to have a switch that easily turns on the light to last state, but then have the more involved controls to change colors and temperature when I’m in the mood to do that.
Note: Any guidance on how to get the ItemID for all the devices connected to the Hue Bridge also would be helpful. I’ve been having to guess a lot. According to these instructions: Philips Hue - Bindings | openHAB I should be able to find them in the Hue App but for the life of me I cannot. I have about 10 lights and 4 switches so having to guess and check is going to be a hassle.
THANK YOU
