What is the reason that the switch state in the android app oder basic ui was not updated after I turn on/off the switch manual?
Here is a example for a binding
Switch Outside <switch> (g_Entry,g_InitializeOFF,g_mySQL) {channel="zwave:device:Stick:node5:switch_binary"}
If neither UI was updates, it is possible that the zwave switch does not report it when someone manually toggles the switch. If the change does show up in one but not the other then it could be one of the known issues that has yet to be fixed,
