Hi…I have got a Pi3 running openhabian and openhab2.0…I ran flawless until now. Suddenly at night openhab looses the network connectivity. Raspi is running on Wifi. I solved that problem rebooting it at 7 a.m. via crontab reboot.
Maybe an update fixes this problem?
Now my questions: do i have to backup my settings?
How do I initiate an update for openhab running openhabian? Via apt-upgrade?
What about habpanel? Are these settings lost after an update?
There is nothing that OH does that would cause this problem. openHABian only runs while executing openhabian-conf so it isn’t causing this problem either.
If it used to work and now has problems the cause is:
something changed in your WiFi config or wireless network that is causing the WiFi to drop
the power being supplied to the RPi is not clean causing it to run erratically
the wifi is failing on the RPi
the SD card is failing on the RPi.
An upgrade of OH or openHABian will not fix your problem.
openHABian has backup and restore scripts so I would recommend using those. I don’t know about HABPanel.
The best would be to initiate the upgrade through openhabian-conf.
Thanks for your reply…i did the update to 2.2 now and deleted my reboot entry in the startup…only to give it a try i will report of the problem persists
