I have an Aeon WallMote configured in PaperUI and now I’m trying to get it setup to control devices using rules, but my rules are never triggered when tapping any of the buttons.
I have four items in my items file. One for each button. Here is an example:
Number scene1 {channel=“zwave:device:8b948369:node5:scene_number1”}
Here is the corresponding rule:
rule "Scene 1"
Item scene1 received update
logInfo(“scene1”, “scene1”)
logInfo(“scene1”, scene1.state.toString)
I see nothing in the logs. I’ve tried using ‘received command’ as well, but nothing is logged. Any ideas? I’m using an Aeon z-stick, by the way.
I got it resolved, I need to add an Item bound to the scene, not the individual scene#'s. So now its working, but I see I’m not getting updates for the battery, so now my question has changed. Does anyone know how to get battery updates working for the WallMote?
I have the same problem, but I cannot see your solution:
Item:
Number Scene_Wallmote “Wallmote Scene Number” {channel=“zwave:device:51afa763:node25:scene_number”}
Rule:
rule “Wallmote”
Item Scene_Wallmote received update
logDebug(“Output”, "Wallmote Button : " + Scene_Wallmote)
In the log I can see the changing of the values when tapping the buttons. But the update does not trigger the rule. Could you explain your solution in detail ?
I was initially using the channel for scene_number1, which was incorrect. the scene_number was the correct one to use. It appears that you are doing that as well.
On second thought, I see a syntax error in your log statement:
I’m not sure about the concatenation, that may be correct, but using simply Scene_Wallmote should produce an error in the logs when the rule is parsed. Try this instead:
logDebug(“Output”, Scene_Wallmote.state.toString)
The logs can only output strings and Scene_Wallmote is an object. You need to get the state of the object and convert that state to a string. Hope this helps.
Concatenation can be used here. Adding the .toString method is cleaner, but the Rules DSL will also “help”, and convert to strings for you, so this will work…
