OS: Raspbian GNU/Linux 10 (buster) / Linux 5.10.63-v7l+
openHAB version:3.1.0 - Release Build
Hi guys. Related to high energy prices, I have some rules that switch on and off the hot water tank. The times vary from day to day. Instead of using the web interface, I was wondering if there was any way to update/set the rules by using files. Like:
Rule 01 - Read value in /tmp/elec/morning-start.txt (02)
Rule 02 - Read value in /tmp/elec/morning-stop.txt (05)
Rule 03 - Read value in /tmp/elec/afternoon-start.txt (13)
Rule 04 - Read value in /tmp/elec/afternoon-stop.txt (16)
Would the iCalendar binding be a solution? iCalendar - Bindings | openHAB
You could trigger individually for every day end have the required values in the calendar.
Not sure if that makes sense for you. I control the heating with that.
Thanks a lot guys for your replies. I will need to check a bit more on the solutions proposed, and it may take some time before I could have a try to implement them.
