Thank you for your reply, looking at openhab-cli logs:
- seems that the user input for ON is correctly detected, then it’s sent to zigbee point (it turn physically ON), anyway if I open a new page with the same switch widget it’s shown as OFF:
2021-10-20 09:37:15.816 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'BV201010ZigBeeUSBdongle_Dataframesreceived' changed from 299 to 331
2021-10-20 09:37:15.817 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'BV201010ZigBeeUSBdongle_Dataframessent' changed from 191 to 221
2021-10-20 09:37:15.819 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'BV201010ZigBeeUSBdongle_ACKframessent' changed from 299 to 331
2021-10-20 09:37:45.814 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'BV201010ZigBeeUSBdongle_Dataframesreceived' changed from 331 to 361
2021-10-20 09:37:45.822 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'BV201010ZigBeeUSBdongle_Dataframessent' changed from 221 to 251
2021-10-20 09:37:45.825 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'BV201010ZigBeeUSBdongle_ACKframessent' changed from 331 to 361
2021-10-20 09:38:15.821 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'BV201010ZigBeeUSBdongle_Dataframesreceived' changed from 361 to 391
2021-10-20 09:38:15.823 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'BV201010ZigBeeUSBdongle_Dataframessent' changed from 251 to 281
2021-10-20 09:38:15.823 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'BV201010ZigBeeUSBdongle_ACKframessent' changed from 361 to 391
2021-10-20 09:38:21.546 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'LegrandLightswitchwithneutral_Switch' received command ON
2021-10-20 09:38:21.564 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 0004740000B5C716: Command for channel zigbee:device:01380FB1:0004740000b5c716:0004740000B5C716_1_switch --> ON [OnOffType]
2021-10-20 09:38:21.565 [DEBUG] [e.transaction.ZigBeeTransactionQueue] - 0004740000B5C716: Added transaction to queue, len=1, transaction=ZigBeeTransaction [ieeeAddress=0004740000B5C716 queueTime=0, state=WAITING, sendCnt=0, command=OnCommand [On/Off: 0000/0 -> 425D/1, cluster=0006, TID=--]]
2021-10-20 09:38:21.566 [DEBUG] [transaction.ZigBeeTransactionManager] - Transaction Manager: Send Next transaction. outstandingTransactions=0, outstandingQueues=1, sleepy=0/3
2021-10-20 09:38:21.566 [DEBUG] [transaction.ZigBeeTransactionManager] - 425D/1: Sending ZigBeeTransaction [ieeeAddress=0004740000B5C716 queueTime=1, state=WAITING, sendCnt=0, command=OnCommand [On/Off: 0000/0 -> 425D/1, cluster=0006, TID=2F]]
2021-10-20 09:38:21.567 [DEBUG] [transaction.ZigBeeTransactionManager] - transactionListenerAdded: 1 outstanding
2021-10-20 09:38:21.567 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX CMD: OnCommand [On/Off: 0000/0 -> 425D/1, cluster=0006, TID=2F]
2021-10-20 09:38:21.568 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX ZCL: ZclHeader [frameType=CLUSTER_SPECIFIC_COMMAND, manufacturerSpecific=false, direction=CLIENT_TO_SERVER, disableDefaultResponse=false, manufacturerCode=0, sequenceNumber=47, commandId=1]
2021-10-20 09:38:21.568 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX APS: ZigBeeApsFrame [sourceAddress=0000/1, destinationAddress=425D/1, profile=0104, cluster=0006, addressMode=DEVICE, radius=8, apsSecurity=false, ackRequest=true, apsCounter=2F, rssi=--, lqi=--, payload=01 2F 01]
2021-10-20 09:38:21.569 [DEBUG] [converter.ZigBeeBaseChannelConverter] - 0004740000B5C716: Channel zigbee:device:01380FB1:0004740000b5c716:0004740000B5C716_1_switch waiting for response to ON
2021-10-20 09:38:21.580 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspSendUnicastResponse [networkId=0, status=EMBER_SUCCESS, sequence=1F]
2021-10-20 09:38:21.627 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspMessageSentHandler [networkId=0, type=EMBER_OUTGOING_DIRECT, indexOrDestination=425D, apsFrame=EmberApsFrame [profileId=0104, clusterId=0006, sourceEndpoint=1, destinationEndpoint=1, options=[EMBER_APS_OPTION_ENABLE_ADDRESS_DISCOVERY, EMBER_APS_OPTION_RETRY, EMBER_APS_OPTION_ENABLE_ROUTE_DISCOVERY], groupId=0, sequence=1F], messageTag=2F, status=EMBER_SUCCESS, messageContents=]
2021-10-20 09:38:21.628 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX STA: msgTag=2F state=RX_ACK
2021-10-20 09:38:21.629 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionProgress: TID=2F, state=RX_ACK, outstanding=1
2021-10-20 09:38:21.630 [DEBUG] [zigbee.transaction.ZigBeeTransaction] - Transaction state changed: nwk=425D, TID=2F, event=RX_ACK, state=ACKED
2021-10-20 09:38:21.650 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspIncomingMessageHandler [networkId=0, type=EMBER_INCOMING_UNICAST, apsFrame=EmberApsFrame [profileId=0104, clusterId=0006, sourceEndpoint=1, destinationEndpoint=1, options=[EMBER_APS_OPTION_RETRY, EMBER_APS_OPTION_ENABLE_ROUTE_DISCOVERY], groupId=0, sequence=DC], lastHopLqi=99, lastHopRssi=-61, sender=425D, bindingIndex=255, addressIndex=255, messageContents=18 2F 0B 01 00]
2021-10-20 09:38:21.651 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX APS: ZigBeeApsFrame [sourceAddress=425D/1, destinationAddress=0000/1, profile=0104, cluster=0006, addressMode=DEVICE, radius=0, apsSecurity=false, ackRequest=false, apsCounter=DC, rssi=-61, lqi=63, payload=18 2F 0B 01 00]
2021-10-20 09:38:21.652 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - 0004740000B5C716: Node update. NWK Address=425D
2021-10-20 09:38:21.652 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - 0004740000B5C716: Node 425D is not updated
2021-10-20 09:38:21.653 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX ZCL: ZclHeader [frameType=ENTIRE_PROFILE_COMMAND, manufacturerSpecific=false, direction=SERVER_TO_CLIENT, disableDefaultResponse=true, manufacturerCode=0, sequenceNumber=47, commandId=11]
2021-10-20 09:38:21.654 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX CMD: DefaultResponse [On/Off: 425D/1 -> 0000/1, cluster=0006, TID=2F, commandIdentifier=1, statusCode=SUCCESS]
2021-10-20 09:38:21.654 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionCommand: DefaultResponse [On/Off: 425D/1 -> 0000/1, cluster=0006, TID=2F, commandIdentifier=1, statusCode=SUCCESS]
2021-10-20 09:38:21.656 [DEBUG] [converter.ZigBeeBaseChannelConverter] - 0004740000B5C716: Channel zigbee:device:01380FB1:0004740000b5c716:0004740000B5C716_1_switch received SUCCESS in response to ON
2021-10-20 09:38:21.656 [DEBUG] [transaction.ZigBeeTransactionManager] - Transaction complete: ZigBeeTransaction [ieeeAddress=0004740000B5C716 queueTime=90, state=COMPLETE, sendCnt=1, command=OnCommand [On/Off: 0000/0 -> 425D/1, cluster=0006, TID=2F]]
2021-10-20 09:38:21.656 [DEBUG] [transaction.ZigBeeTransactionManager] - transactionListenerRemoved: 0 outstanding
2021-10-20 09:38:21.658 [DEBUG] [e.transaction.ZigBeeTransactionQueue] - 0004740000B5C716: transactionComplete, state=COMPLETE, outstanding=0
2021-10-20 09:38:21.658 [DEBUG] [transaction.ZigBeeTransactionManager] - Transaction Manager: Send Next transaction. outstandingTransactions=0, outstandingQueues=0, sleepy=0/
- I’ve a shelly widget but this one seems to act correctly, this one on both web clients act syncend:
2021-10-20 09:42:39.700 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Shelly1SHSW1_Potenza' received command ON
2021-10-20 09:42:39.713 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Shelly1SHSW1_Potenza' predicted to become ON
2021-10-20 09:42:39.720 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Shelly1SHSW1_Potenza' changed from OFF to ON
I’m using latest openhabian 32 bit image:
Version: 3.1.0 (Build)
User: openhab (Active Process 708)
User Groups: openhab tty dialout audio bluetooth gpio
############### openhabian ##################################################
Release = Raspbian GNU/Linux 10 (buster)
Kernel = Linux 5.10.63-v7l+
Platform = Raspberry Pi 4 Model B Rev 1.2
Uptime = 0 day(s). 0:10:55
CPU Usage = 0.25% avg over 4 cpu(s) (4 core(s) x 1 socket(s))
CPU Load = 1m: 0.03, 5m: 0.11, 15m: 0.12
Memory = Free: 3.16GB (83%), Used: 0.63GB (17%), Total: 3.79GB
Swap = Free: 0.53GB (100%), Used: 0.00GB (0%), Total: 0.53GB
Root = Free: 3.43GB (52%), Used: 3.13GB (48%), Total: 6.89GB
Updates = 0 apt updates available.
Sessions = 1 session(s)
Processes = 123 running processes of 32768 maximum processes
_ _ _ ____ _
___ ___ ___ ___ | | | | / \ | __ ) () ____ ___
/ _ \ / _ \ / _ \ / _ \ | || | / _ \ | _ \ | | / _ \ / _ \
| () | () | /| | | || _ | / ___ \ | |) )| || () || | | |
_/| / _/|| |||| ||// _|/ || _|||| | |
|| 3.1.0 - Release Build
Thanks, BR
