Hi guys,
I’ve tried to update using the openhabian-config tool. However it stops with a failure, so that my installation is no longer usable right now:
Here is the output when I try to run the update again:
openhabian@openhab:~$ sudo openhabian-config
[sudo] password for openhabian:
2018-10-25_14:55:43_CEST [openHABian] Checking for root privileges… OK
2018-10-25_14:55:43_CEST [openHABian] Loading configuration file ‘/etc/openhabian.conf’… OK
2018-10-25_14:55:43_CEST [openHABian] openHABian configuration tool version: [master]v1.4.1-416(de039da)
2018-10-25_14:55:44_CEST [openHABian] Checking for changes in origin… OK
2018-10-25_14:55:51_CEST [openHABian] Updating repositories and upgrading installed packages…
$ apt update
Hit:1 p://archive.raspberrypi.org/debian stretch InRelease
Get:2 ://raspbian.raspberrypi.org/raspbian stretch InRelease [15.0 kB]
Ign:3 ://repos.azulsystems.com/debian stable InRelease
Hit:4 ://repos.azulsystems.com/debian stable Release
Ign:5 ://dl.bintray.com/openhab/apt-repo2 stable InRelease
Hit:6 ://dl.bintray.com/openhab/apt-repo2 stable Release
Hit:7 ://deb.nodesource.com/node_8.x stretch InRelease
Get:8 ://raspbian.raspberrypi.org/raspbian stretch/main armhf Packages [11.7 MB]
Fetched 11.7 MB in 11s (1,045 kB/s)
Reading package lists… Done
Building dependency tree
Reading state information… Done
All packages are up to date.
$ apt --yes upgrade
Calculating upgrade… Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
5 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Setting up python2.7 (2.7.13-2+deb9u3) …
Sorry: TypeError: compile() expected string without null bytes
dpkg: error processing package python2.7 (–configure):
subprocess installed post-installation script returned error exit status 1
dpkg: dependency problems prevent configuration of samba:
samba depends on python2.7:any; however:
Package python2.7 is not configured yet.
dpkg: error processing package samba (–configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of samba-common-bin:
samba-common-bin depends on python2.7:any; however:
dpkg: error processing package samba-common-bin (–configure):
dpkg: dependency problems prevent configuration of python2.7-dev:
python2.7-dev depends on python2.7 (= 2.7.13-2+deb9u3); however:
dpkg: error processing package python2.7-dev (–configure):
dpkg: dependency problems prevent configuration of python-dev:
python-dev depends on python2.7-dev (>= 2.7.13-1~); however:
Package python2.7-dev is not configured yet.
dpkg: error processing package python-dev (–configure):
Errors were encountered while processing:
python2.7
samba
samba-common-bin
python2.7-dev
python-dev
Updating FireMotD available updates count … 2018-10-25 14:57:09,820: FireMotD: Error: Template folder doesn’t exist. Upgrading from an older version? Please run make again or run the install function “FireMotD -I -v”.
E: Sub-process /usr/bin/dpkg returned an error code (1)
FAILED
[18:57:09] openhabian@openhab:~$ sudo openhabian-config
During the first run, it did ask about the smb.conf (keep or use new) and I had selected to use a new one. Other than that, no interaction was required up until when the error came…
Hope you can help to save my system… Had lot’s of KNX configs done through PaperUI which I wouldn’t know how to restore…
thanks!
