Hi all,
i have a fibaro FGS-212 singele Relay switch. To use it i update openhab to 1.8.0 Snapshot.
Somethings happend:
the FGS-212 is include well - but it’s a singel relay. In the Propertys there are two switches (1 + 2)
at this point my Z-Wave Controller is shown as dead - it’s a Aeon Z-Stick S2!
when i downgrade to 1.7.1 the Stick ist ok but then the FGS-212 is not initializised not correct.
Thanks for Help.
chris
(Chris Jackson)
October 23, 2015, 4:13pm
2
A debug log file is always useful…
What properties do you mean exactly? You know of course that while the FGS212 only has 1 relay, it can control two switches?
Hi Chris,
yes, but in the log there are two endpoints:
2015-10-23 17:48:45.176 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 23: No item bound for event, endpoint = 1, command class = SWITCH_BINARY, value = 0, ignoring.
2015-10-23 17:48:45.274 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 23: No item bound for event, endpoint = 2, command class = SWITCH_BINARY, value = 0, ignoring.
chris
(Chris Jackson)
October 25, 2015, 6:03pm
4
Yes, that’s exactly my point - there are two switches/endpoints that this device controls.
Thanks Chris - with this point of view i understand Switch and device. Perfekt!
One problem leaves:
Version 1.7.1 - Aeon Z-Stick S2 ok, FGS-212 is not recognize with
Version 1.8.0 (SNAPSHOT) the FGS-212 is known well bat the Aeon Z-Stick S2 is dead (red dot).
I hope you can help
Best reguards
Hubertus
Two switches (input) to control one output relay.
