Hello again, I tried to update to latest stable 2.3.0 and it failed.
See here for the start
Update seems to go well, but when I restart the openhab service, it doesn’t work, log below
Thanks for any advice
EDIT FIXED
I eventually fixed it with this
https://community.openhab.org/t/can-not-start-after-nightly-update/22934/4?u=aymeric106
sudo apt-get remove openhab2
sudo apt-get remove openhab2-addons
Do NOT do purge then you lose your configuration
sudo apt-get install openhab2
sudo apt-get install openhab2-addons
Aymeric
2018-06-02 15:27:16.974 [ERROR] [org.eclipse.smarthome.core.audio ] - FrameworkEvent ERROR - org.eclipse.smarthome.core.audio
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.smarthome.core.audio [102]
Unresolved requirement: Import-Package: org.eclipse.jdt.annotation; resolution:="optional"
Unresolved requirement: Import-Package: org.eclipse.smarthome.config.core
-> Export-Package: org.eclipse.smarthome.config.core; bundle-symbolic-name="org.eclipse.smarthome.config.core"; bundle-version="0.10.0.oh230"; version="0.0.0"
org.eclipse.smarthome.config.core [96]
Unresolved requirement: Import-Package: org.eclipse.smarthome.core.common.osgi
-> Export-Package: org.eclipse.smarthome.core.common.osgi; bundle-symbolic-name="org.eclipse.smarthome.core"; bundle-version="0.10.0.oh230"; version="0.0.0"
org.eclipse.smarthome.core [101]
Unresolved requirement: Import-Package: tec.uom.lib.common
-> Export-Package: org.eclipse.smarthome.core.common; bundle-symbolic-name="org.eclipse.smarthome.core"; bundle-version="0.10.0.oh230"; version="0.0.0"
Unresolved requirement: Import-Package: org.eclipse.smarthome.core.common.registry
-> Export-Package: org.eclipse.smarthome.core.common.registry; bundle-symbolic-name="org.eclipse.smarthome.core"; bundle-version="0.10.0.oh230"; version="0.0.0"
at org.eclipse.osgi.container.Module.start(Module.java:444) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1634) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1613) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1585) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1528) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) [?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340) [?:?]
2018-06-02 15:27:17.032 [ERROR] [rg.eclipse.smarthome.core.autoupdate] - FrameworkEvent ERROR - org.eclipse.smarthome.core.autoupdate
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.smarthome.core.autoupdate [103]
Unresolved requirement: Import-Package: org.eclipse.smarthome.core.events
-> Export-Package: org.eclipse.smarthome.core.events; bundle-symbolic-name="org.eclipse.smarthome.core"; bundle-version="0.10.0.oh230"; version="0.0.0"; uses:="org.eclipse.smarthome.core.items,org.osgi.service.event,org.eclipse.smarthome.core.types"
Unresolved requirement: Import-Package: org.eclipse.smarthome.core.items
-> Export-Package: org.eclipse.smarthome.core.items; bundle-symbolic-name="org.eclipse.smarthome.core"; bundle-version="0.10.0.oh230"; version="0.0.0"; uses:="org.eclipse.smarthome.core.types,org.eclipse.smarthome.core.events"
2018-06-02 15:27:17.045 [ERROR] [g.eclipse.smarthome.core.persistence] - FrameworkEvent ERROR - org.eclipse.smarthome.core.persistence
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.smarthome.core.persistence [106]
2018-06-02 15:27:17.060 [ERROR] [org.eclipse.smarthome.core.voice ] - FrameworkEvent ERROR - org.eclipse.smarthome.core.voice
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.smarthome.core.voice [111]
Unresolved requirement: Import-Package: org.eclipse.smarthome.core.audio
-> Export-Package: org.eclipse.smarthome.core.audio; bundle-symbolic-name="org.eclipse.smarthome.core.audio"; bundle-version="0.10.0.oh230"; version="0.0.0"
2018-06-02 15:27:17.082 [ERROR] [org.eclipse.smarthome.io.console ] - FrameworkEvent ERROR - org.eclipse.smarthome.io.console
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.smarthome.io.console [112]
2018-06-02 15:27:17.095 [ERROR] [org.eclipse.smarthome.io.javasound ] - FrameworkEvent ERROR - org.eclipse.smarthome.io.javasound
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.smarthome.io.javasound [114]
Unresolved requirement: Import-Package: org.eclipse.smarthome.core.library.types
-> Export-Package: org.eclipse.smarthome.core.library.types; bundle-symbolic-name="org.eclipse.smarthome.core"; bundle-version="0.10.0.oh230"; version="0.0.0"
2018-06-02 15:27:17.121 [ERROR] [org.eclipse.smarthome.io.net ] - FrameworkEvent ERROR - org.eclipse.smarthome.io.net
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.smarthome.io.net [116]
Unresolved requirement: Import-Package: org.osgi.service.http
2018-06-02 15:27:17.127 [ERROR] [org.eclipse.smarthome.io.rest.voice ] - FrameworkEvent ERROR - org.eclipse.smarthome.io.rest.voice
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.smarthome.io.rest.voice [123]
Unresolved requirement: Import-Package: org.eclipse.smarthome.core.voice.text
-> Export-Package: org.eclipse.smarthome.core.voice.text; bundle-symbolic-name="org.eclipse.smarthome.core.voice"; bundle-version="0.10.0.oh230"; version="0.0.0"
-> Export-Package: org.eclipse.smarthome.core.voice; bundle-symbolic-name="org.eclipse.smarthome.core.voice"; bundle-version="0.10.0.oh230"; version="0.0.0"
Unresolved requirement: Import-Package: org.eclipse.smarthome.core.auth
-> Export-Package: org.eclipse.smarthome.core.auth; bundle-symbolic-name="org.eclipse.smarthome.core"; bundle-version="0.10.0.oh230"; version="0.0.0"
2018-06-02 15:27:17.136 [ERROR] [org.eclipse.smarthome.io.webaudio ] - FrameworkEvent ERROR - org.eclipse.smarthome.io.webaudio
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.smarthome.io.webaudio [125]
2018-06-02 15:27:17.142 [ERROR] [org.eclipse.smarthome.model.core ] - FrameworkEvent ERROR - org.eclipse.smarthome.model.core
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.smarthome.model.core [126]
Unresolved requirement: Import-Package: com.google.inject
-> Export-Package: com.google.inject; bundle-symbolic-name="com.google.inject"; aop="false"; bundle-version="3.0.0.v201312141243"; version="1.3.0"
com.google.inject [24]
Unresolved requirement: Import-Package: javax.inject
Unresolved requirement: Import-Package: org.eclipse.smarthome.core.service
-> Export-Package: org.eclipse.smarthome.core.service; bundle-symbolic-name="org.eclipse.smarthome.core"; bundle-version="0.10.0.oh230"; version="0.0.0"
2018-06-02 15:27:17.171 [ERROR] [org.eclipse.smarthome.model.rule ] - FrameworkEvent ERROR - org.eclipse.smarthome.model.rule
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.smarthome.model.rule [134]
2018-06-02 15:27:17.177 [ERROR] [eclipse.smarthome.model.rule.runtime] - FrameworkEvent ERROR - org.eclipse.smarthome.model.rule.runtime
etc etc
