Hello, when updating openhabian-config tool to upgrade to version 3.4 from 3.3 an error pops up - no space left.
[sudo] password for openhabian:
2022-10-13_16:12:26_CEST [openHABian] Checking for root privileges… OK
2022-10-13_16:12:26_CEST [openHABian] Loading configuration file ‘/etc/openhabian.conf’… OK
2022-10-13_16:12:26_CEST [openHABian] openHABian configuration tool version: [openHAB3]{2022-08-24T11:37:05+02:00}(4a11e45)
2022-10-13_16:12:27_CEST [openHABian] Checking for changes in origin branch openHAB3… OK
2022-10-13_16:12:30_CEST [openHABian] Switching to branch openHAB3… OK
2022-10-13_16:12:30_CEST [openHABian] Adding slightly tuned bash configuration files to system… OK
2022-10-13_16:12:34_CEST [openHABian] Updating Linux package information… OK
2022-10-13_16:12:38_CEST [openHABian] Updating repositories and upgrading installed packages…
Reading package lists… Done
Building dependency tree… Done
Reading state information… Done
Calculating upgrade… Done
The following packages have been kept back:
raspberrypi-net-mods raspberrypi-sys-mods
The following packages will be upgraded:
bluez dbus dhcpcd5 isc-dhcp-client isc-dhcp-common libbluetooth-dev libbluetooth3 libdbus-1-3 libuv1
9 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
Need to get 2,293 kB of archives.
After this operation, 4,096 B of additional disk space will be used.
Get:1 Index of /debian bullseye/main armhf bluez armhf 5.55-3.1+rpt2 [844 kB]
Get:4 Index of /debian bullseye/main armhf dhcpcd5 armhf 1:8.1.2-1+rpt8 [145 kB]
Get:5 Index of /debian bullseye/main armhf libbluetooth-dev armhf 5.55-3.1+rpt2 [221 kB]
Get:7 Index of /debian bullseye/main armhf libbluetooth3 armhf 5.55-3.1+rpt2 [106 kB]
Get:2 Index of /raspbian bullseye/main armhf dbus armhf 1.12.24-0+deb11u1 [219 kB]
Get:3 Index of /raspbian bullseye/main armhf libdbus-1-3 armhf 1.12.24-0+deb11u1 [197 kB]
Get:6 Index of /raspbian bullseye/main armhf isc-dhcp-client armhf 4.4.1-2.3+deb11u1 [296 kB]
Get:8 Index of /raspbian bullseye/main armhf isc-dhcp-common armhf 4.4.1-2.3+deb11u1 [145 kB]
Get:9 Index of /pub/Linux/distributions/raspbian/raspbian bullseye/main armhf libuv1 armhf 1.40.0-2 [119 kB]
Fetched 2,293 kB in 1s (1,605 kB/s)
apt-listchanges: Reading changelogs…
dpkg: cannot write to log file ‘/var/log/dpkg.log’: No space left on device
(Reading database … 55951 files and directories currently installed.)
Preparing to unpack …/0-dbus_1.12.24-0+deb11u1_armhf.deb …
Unpacking dbus (1.12.24-0+deb11u1) over (1.12.20-2) …
Preparing to unpack …/1-libdbus-1-3_1.12.24-0+deb11u1_armhf.deb …
this will show the different partitions on your sd card and it’s usage.
Looks like the /var/log space is full and either too small or the space is just being filled up too fast.
The df command will show the sizes of the partitions and their usage.
Before increasing the size I would check for the root cause that is responsible that there is no free space.On my pi the size of that area is as well 420MB but 26MB are occupied.
Older logs are normally compressed/zipped that even could mean that the area is full due to recent data.
What is the output of sudo du -k -s /var/log/* | sort -n
In your previous post the /var/log/ related zram/overlay was occupied to 100%
This time it is filled to 15% which should be ok.
I am wondering why there are that many zram entries while for several of them the matching overlay entry is missing.
I also do not see the openhab directory under /var/log.
As in previous post /var/log/ resp. zram/overlay was full to 100% it was not possible to run the update command. This should be ok now according to the information you provided.
Did you do anything which resulted in getting all these orphaned zram ( 2, 4, 5 8 ) entries ?
I would say as the logviewer is just used to view the data that is logged it is not the problem.
The data that is being logged could be the problem because of log level and amount of data.
Storing data in graph should be stored in persistence directory shouldn’t it ?
Persistence is 27MB compared to 411 MB in /var/log.
Dig deeper into /var/log to check amount of files and it’s file sizes.
E.g. check how much space is used in /var/log/openhab ( du -s -h /var/log/openhab/ ).
What do you need to log and which log level is enabled in logging for mosquitto ?
I would suggest just log the error level apart of if you need a higher level.
Are there several files kept in history of the mosquitto folder in /var/log ? In case you do not need the full history that also should be configurable to just keep the current one and n further files.
mosquitto configuration files can be found in /etc/mosquitto and /etc/mosquitto/conf.d.
/etc/mosquitto/mosquitto.conf is the distributions configuration file. In /etc/mosquitto/conf.d/ you may have added your configuration changes.
In one of the files there should be an entry log_type.
Logging then can have these log levels:
log_typetypes
Choose types of messages to log. Possible types are: debug, error, warning, notice, information, subscribe, unsubscribe, websockets, none, all.
Defaults to error, warning, *notice *and information. This option may be specified multiple times. Note that the *debug *type (used for decoding incoming/outgoing network packets) is never logged in topics.
# Place your local configuration in /etc/mosquitto/conf.d/
# A full description of the configuration file is at
# /usr/share/doc/mosquitto/examples/mosquitto.conf.example
pid_file /var/run/mosquitto.pid
persistence true
persistence_location /var/lib/mosquitto/
log_dest file /var/log/mosquitto/mosquitto.log
include_dir /etc/mosquitto/conf.d
password_file /etc/mosquitto/passwd
allow_anonymous false
