I downloaded the latest snapshot openhab 2.0, ran it and installed HABMIN + Z-wave bindning via paperUI.
Installed the z-wave controller and it discovered all my nodes.
However, all are device unknown, and these are units that are known in your database.
I can’t find if openhab or the z-wave binding downloads the main xml file for all devices.
Or should I manually install it? I can’t find a download link on your website if this is the case.
I’m using openhab on windows 7 x64 if this matters.
And the snapshot was from yesterday around 19:00 CET
I downloaded the offline distribution from cloudbees.
I clicked permalinks 534 and then downloaded openhab-offline-2.0.0-SNAPSHOT.zip
The z-wave bindning is downloaded (or installed) from within paperUI.
I take it this should be the latest. Or atleast for that snapshot?
When I come home, I’ll try to see what version it is (I think I could use LIST to see which version it is?).
Hmmm - not sure what you mean. I think your statement is correct - the offline version will contain the latest versions, but if you use the offline version then you can’t update the binding using the “normal” update mechanism of uninstalling a binding, and re-installing it again. Doing this in an offline version will install the same version from the offline runtime (ie no update).
Does that answer your question or did I misunderstand .
