@chris
cleaning my long post up…
I am partially going insane here. Can you please take a look at this debug log?
I am setting config item 80/1 to 3. it seems to be working but when it pulls the report it still says 80/1 to 0.
The configuration is not acutally being set. What might be happening?
this is 2.4M8 snapshot and binding
it is now happening on all my devices, even though they have been re-added as per update note
2018-12-12 22:06:53.929 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Configuration update set config_80_1 to 3 (BigDecimal)
2018-12-12 22:06:53.930 [DEBUG] [class.ZWaveConfigurationCommandClass] - NODE 12: Creating new message for application command CONFIGURATION_SET
2018-12-12 22:06:53.930 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 12: SECURITY not supported
2018-12-12 22:06:53.930 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 12: Command Class COMMAND_CLASS_CONFIGURATION is NOT required to be secured
2018-12-12 22:06:53.930 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 12: Adding to device queue
2018-12-12 22:06:53.930 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 12: Added 91 to queue - size 3
2018-12-12 22:06:53.931 [DEBUG] [class.ZWaveConfigurationCommandClass] - NODE 12: Creating new message for application command CONFIGURATIONCMD_GET
2018-12-12 22:06:53.931 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 12: SECURITY not supported
2018-12-12 22:06:53.933 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 12: Command Class COMMAND_CLASS_CONFIGURATION is NOT required to be secured
2018-12-12 22:06:53.933 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 12: Adding to device queue
2018-12-12 22:06:53.933 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 12: Added 92 to queue - size 4
2018-12-12 22:06:53.934 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Configuration update ignored config_255_4 to 0 (BigDecimal)
2018-12-12 22:06:53.934 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Configuration update set action_failed to false (Boolean)
2018-12-12 22:06:53.934 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Configuration update set action_remove to false (Boolean)
2018-12-12 22:06:53.934 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Configuration update set binding_pollperiod to 86400 (BigDecimal)
2018-12-12 22:06:53.935 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Polling intialised at 86400 seconds - start in 14169600 milliseconds.
2018-12-12 22:06:53.935 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Configuration update set action_heal to false (Boolean)
2018-12-12 22:06:53.935 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Configuration update ignored config_122_1 to 0 (BigDecimal)
2018-12-12 22:06:53.935 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Configuration update ignored config_120_1 to 1 (BigDecimal)
2018-12-12 22:06:53.935 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Configuration update ignored config_121_1 to 1 (BigDecimal)
2018-12-12 22:06:53.936 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Configuration update ignored config_4_1 to 0 (BigDecimal)
2018-12-12 22:06:53.936 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Configuration update ignored config_87_4 to 0 (BigDecimal)
2018-12-12 22:06:53.936 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Configuration update ignored node_id to 12 (BigDecimal)
2018-12-12 22:06:53.936 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Configuration update ignored config_86_4 to 0 (BigDecimal)
2018-12-12 22:06:53.944 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 12: SendData Request. CallBack ID = 69, Status = Transmission complete and ACK received(0)
2018-12-12 22:06:53.944 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 12: resetResendCount initComplete=true isDead=false
2018-12-12 22:06:53.944 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 12: TID 88: Transaction not completed
2018-12-12 22:06:53.962 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 12: Application Command Request (ALIVE:DONE)
2018-12-12 22:06:53.962 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 12: resetResendCount initComplete=true isDead=false
2018-12-12 22:06:53.963 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 12: Incoming command class COMMAND_CLASS_MULTI_CHANNEL_ASSOCIATION, endpoint 0
2018-12-12 22:06:53.963 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 12: SECURITY not supported
2018-12-12 22:06:53.963 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 12: Received COMMAND_CLASS_MULTI_CHANNEL_ASSOCIATION V3 MULTI_ASSOCIATIONCMD_REPORT
2018-12-12 22:06:53.963 [DEBUG] [ss.ZWaveMultiAssociationCommandClass] - NODE 12: association group 3 has max associations 5
2018-12-12 22:06:53.963 [DEBUG] [ss.ZWaveMultiAssociationCommandClass] - NODE 12: Association group 3 includes the following nodes:
2018-12-12 22:06:53.963 [DEBUG] [ss.ZWaveMultiAssociationCommandClass] - NODE 12: Associated with Node 1 endpoint 1 in group
2018-12-12 22:06:53.963 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Got an event from Z-Wave network: ZWaveAssociationEvent
2018-12-12 22:06:53.963 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Got a value event from Z-Wave network, endpoint = 0, command class = COMMAND_CLASS_ASSOCIATION, value = 0
2018-12-12 22:06:53.963 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 12: Commands processed 1.
2018-12-12 22:06:53.963 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 12: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@2d30ad18.
2018-12-12 22:06:53.964 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 12: Command verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@2d30ad18.
2018-12-12 22:06:53.964 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 12: notifyTransactionResponse TID:88 DONE
2018-12-12 22:06:53.974 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2018-12-12 22:06:53.975 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 12: Sending REQUEST Message = 01 0A 00 13 0C 03 8E 04 02 25 46 02
2018-12-12 22:06:53.984 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 12: sentData successfully placed on stack.
2018-12-12 22:06:53.984 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 12: TID 89: Transaction not completed
2018-12-12 22:06:54.004 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 12: SendData Request. CallBack ID = 70, Status = Transmission complete and ACK received(0)
2018-12-12 22:06:54.004 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 12: resetResendCount initComplete=true isDead=false
2018-12-12 22:06:54.004 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 12: Response processed after 29ms
2018-12-12 22:06:54.004 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 12: TID 89: Transaction completed
2018-12-12 22:06:54.005 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 12: notifyTransactionResponse TID:89 DONE
2018-12-12 22:06:54.011 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2018-12-12 22:06:54.011 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 12: Sending REQUEST Message = 01 0A 00 13 0C 03 8E 02 02 25 47 05
2018-12-12 22:06:54.019 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 12: sentData successfully placed on stack.
2018-12-12 22:06:54.020 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 12: TID 90: Transaction not completed
2018-12-12 22:06:54.041 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 12: SendData Request. CallBack ID = 71, Status = Transmission complete and ACK received(0)
2018-12-12 22:06:54.041 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 12: resetResendCount initComplete=true isDead=false
2018-12-12 22:06:54.041 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 12: TID 90: Transaction not completed
2018-12-12 22:06:54.057 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 12: Application Command Request (ALIVE:DONE)
2018-12-12 22:06:54.057 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 12: resetResendCount initComplete=true isDead=false
2018-12-12 22:06:54.057 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 12: Incoming command class COMMAND_CLASS_MULTI_CHANNEL_ASSOCIATION, endpoint 0
2018-12-12 22:06:54.057 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 12: SECURITY not supported
2018-12-12 22:06:54.057 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 12: Received COMMAND_CLASS_MULTI_CHANNEL_ASSOCIATION V3 MULTI_ASSOCIATIONCMD_REPORT
2018-12-12 22:06:54.057 [DEBUG] [ss.ZWaveMultiAssociationCommandClass] - NODE 12: association group 2 has max associations 5
2018-12-12 22:06:54.057 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Got an event from Z-Wave network: ZWaveAssociationEvent
2018-12-12 22:06:54.057 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Got a value event from Z-Wave network, endpoint = 0, command class = COMMAND_CLASS_ASSOCIATION, value = 0
2018-12-12 22:06:54.058 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 12: Commands processed 1.
2018-12-12 22:06:54.058 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 12: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@61fd77fb.
2018-12-12 22:06:54.058 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 12: Command verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@61fd77fb.
2018-12-12 22:06:54.058 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 12: notifyTransactionResponse TID:90 DONE
2018-12-12 22:06:54.059 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2018-12-12 22:06:54.059 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 12: Sending REQUEST Message = 01 0C 00 13 0C 05 70 04 50 01 03 25 48 A2
2018-12-12 22:06:54.068 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 12: sentData successfully placed on stack.
2018-12-12 22:06:54.068 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 12: TID 91: Transaction not completed
2018-12-12 22:06:54.089 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 12: SendData Request. CallBack ID = 72, Status = Transmission complete and ACK received(0)
2018-12-12 22:06:54.090 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 12: resetResendCount initComplete=true isDead=false
2018-12-12 22:06:54.090 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 12: Response processed after 31ms
2018-12-12 22:06:54.090 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 12: TID 91: Transaction completed
2018-12-12 22:06:54.090 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 12: notifyTransactionResponse TID:91 DONE
2018-12-12 22:06:54.090 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2018-12-12 22:06:54.090 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 12: Sending REQUEST Message = 01 0A 00 13 0C 03 70 05 50 25 49 A0
2018-12-12 22:06:54.098 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 12: sentData successfully placed on stack.
2018-12-12 22:06:54.098 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 12: TID 92: Transaction not completed
2018-12-12 22:06:54.120 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 12: SendData Request. CallBack ID = 73, Status = Transmission complete and ACK received(0)
2018-12-12 22:06:54.120 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 12: resetResendCount initComplete=true isDead=false
2018-12-12 22:06:54.120 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 12: TID 92: Transaction not completed
2018-12-12 22:06:54.136 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 12: Application Command Request (ALIVE:DONE)
2018-12-12 22:06:54.136 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 12: resetResendCount initComplete=true isDead=false
2018-12-12 22:06:54.136 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 12: Incoming command class COMMAND_CLASS_CONFIGURATION, endpoint 0
2018-12-12 22:06:54.136 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 12: SECURITY not supported
2018-12-12 22:06:54.136 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 12: Received COMMAND_CLASS_CONFIGURATION V1 CONFIGURATIONCMD_REPORT
2018-12-12 22:06:54.136 [DEBUG] [class.ZWaveConfigurationCommandClass] - NODE 12: Node configuration report, parameter = 80, value = 0, size = 1
2018-12-12 22:06:54.136 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Got an event from Z-Wave network: ZWaveConfigurationParameterEvent
2018-12-12 22:06:54.137 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Got a value event from Z-Wave network, endpoint = 0, command class = COMMAND_CLASS_CONFIGURATION, value = org.openhab.binding.zwave.internal.protocol.ZWaveConfigurationParameter@65f9ed7e
2018-12-12 22:06:54.137 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Update CONFIGURATION 80/1 to 0
2018-12-12 22:06:54.137 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 12: Commands processed 1.
2018-12-12 22:06:54.137 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 12: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@4b8aac66.
2018-12-12 22:06:54.137 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 12: Command verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@4b8aac66.
