How can I assign a NaN to a channel with a Number type? Before it is assigned any value, it has a NaN state so it should be possible somehow to assign it later even after it had been assigned a number, if this number is not up to date anymore.
You should pass UnDefType.UNDEF as the state. NaN is just what paperUI displays for NULL or UNDEF states.
@pacive, thank you for your fast reply. From the description, this indeed seems the right class to use. However, when I do this: updateState(name, UnDefType.UNDEF);
it returns an error because updateState() does not support UnDefType as second argument. Any idea what might help?
I also think it is strange that no ver.2 binding uses UnDefType.UNDEF at all… only some ver.1 bindings. Is it possible that nobody has the requirement of setting a channel to undef?
I use it in the smhi binding in certain cases:
private void updateChannel(Channel channel, @Nullable BigDecimal value) {
String id = channel.getUID().getIdWithoutGroup();
State newState = UnDefType.NULL;
if (value != null) {
switch (id) {
case PERCENT_FROZEN:
// Smhi returns -9 for spp if there's no precipitation, convert to UNDEF
if (value.intValue() == -9) {
newState = UnDefType.UNDEF;
} else {
newState = new QuantityType<>(value, SmartHomeUnits.PERCENT);
break;
updateState(channel.getUID(), newState);
Try updateState(name, (State) UnDefType.UNDEF);
and see if that helps.
You need org.eclipse.smarthome.core.types.UnDefType
That was it. Before, it had included org.openhab.core.types.UnDefType
, and it did not work. With ‘your’ smarthome class it works perfectly. Thank you!
Just for completeness. The org.openhab.core.types.UnDefType
is from the openHAB 1 compatibility layer. In Eclipse this library is in the path and therefor you can end up using that class.
With openHAB 3 the namespace org.eclipse
will be gone, as well as the openHAB 1 compatibility layer. As a result in openHAB 3 you would actually do need to include org.openhab.core.types.UnDefType
, but it’s the class that is currently in org.eclipse
namespace.
