Hello Community
I run an OH2 Installation (stable version) on an Ubuntu, repository installation.
Now I should update my zWave binding (thanks Chris for adding the devices to the DB). But I only want to update the zWave binding.
Which steps are necessary to archive this?
Thank you!
Michael
sihui
(SiHui)
May 8, 2017, 9:32am
2
Uninstall the binding (also delete it from addons.cfg if applicable), download the version you want to use, put it in your addons folder.
You may need to start the binding manually through Karaf console and also take a look at this post:
Dim:
On a completely clean installation of OH2 Snapshot (#771 ), you will get the following error when you try to start the new Z-Wave binding: openhab> bundle:start org.openhab.binding.zwave Error executing command: Error executing command on bundles: Error starting bundle 208: Could not resolve module: org.openhab.binding.zwave [208] Unresolved requirement: Import-Package: gnu.io To fix this: feature:install openhab-transport-serial and then Z-Wave will start
