Gents!
Been plugging along a bit messing around when I have time away from work. Slowing down due to the holidays (YAY!)
I was making a change to the HEM parameter to tweak Voltage to calculate power usage, and it seems to update but then throws 404 error in Paper UI.
When I switch to habmin - It works. The below messages in the log are as follows.
Attempt to change in Paper UI - error
Attempt to HABmin - Success
11:07:38.405 [INFO ] [ome.io.rest.core.thing.ThingResource] - Received HTTP PUT request for update config at 'things/zwave:device:f9a3def8:node2/config' for the unknown thing 'zwave:device:f9a3def8:node2'.
11:08:30.487 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'zwave:device:f9a3def8:node2' has been updated.
11:08:30.492 [INFO ] [marthome.event.ConfigStatusInfoEvent] - ConfigStatusInfo [configStatusMessages=[ConfigStatusMessage [parameterName=config_1_2, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null]]]
