Upgrade has killed my install - desperate times
I’ve got a very similar issue since yesterday evening, after I deleted my openhab/userdata directory.
I’m running OH2.2.0 in a docker environment and had some issues with my homematic binding, which I could mitigate by deleting the openhab/userdata directory when my thermostats stopped working with openhab from time to time.
This time openhab is not able to acquire the bindings, my error message mirror the one @bulletprooffool shows above.
==> /log/openhab2/logs/openhab.log <==
2018-01-06 11:12:08.629 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing ‘openhab-binding-hue, openhab-binding-yahooweather, openhab-persistence-influxdb, openhab-binding-weather1, openhab-ui-habpanel, openhab-persistence-mysql, openhab-transformation-regex, openhab-binding-yamahareceiver, openhab-binding-mqtt1, openhab-ui-basic, openhab-misc-homekit, openhab-binding-fritzboxtr0641, openhab-binding-astro, openhab-binding-icloud, openhab-ui-habmin, openhab-binding-homematic, openhab-ui-paper’: Error:
Error downloading mvn:org.openhab.io/org.openhab.io.transport.mqtt/1.11.0
Error downloading mvn:org.openhab.binding/org.openhab.binding.mqtt/1.11.0
The same configuration worked before, so it seems to me that the repositories are not available as they usually are.
Similar threads have come up since yesterday evening:
Does anybody have an idea what can cause this?
I’m pretty sure that I did not change anything since the last successful startup of my docker environment and this one…
Kind regards,
Simon
