i try to upgrade my openhab version like mentioned on the github:
openHABian
If you are working with an openHABian setup, the upgrade is quite easy. Regardless of if you are currently using the openHAB 2.2 stable release or one of the latest 2.2 SNAPSHOT builds, switching to openHAB 2.3.0 stable is done in just a few steps:
Connect to the SSH command line and execute: sudo openhabian-config
Select the "Update" option
Wait for the openHABian update to finish, reenter the openHABian configuration tool
Select the "openHAB 2.3.0 stable" option
but when doing this i have no menu point openhab 2.3.0 stable… its still openhab 2.2.0 stable there.
I also made the normal update procedure before:
sudo apt-get update
sudo apt-get upgrade
so has anyone an idea how to force the upgrade to version 2.3.0 ?
saludos
Oliver
