Upgraded to 5.0.1 from 4.3.0 and having Amazon Echo Control issues
Hi all,
Made the upgrade and i noticed that i cannot send any commands to my echo’s since the upgrade.
I cant set volume, send announcements, use tts, play music from commands sent from OH 5.0.1. Echos work to control OH devices, and They work with normal voice commands.
No errors logged in the log file. Trace shows the command being sent.
All devices are Online and i removed and readded the bridge to confirm that wasn’t an issue.
The binding has been significantly revised. Everything only worked again for me after deleting the echo-things and getting them rediscovered. If the things have the same IDs, the items don’t need to be reconnected; they match automatically.
Thank you. All is working again!
