Hi
I updated to the latest build and zwave version.
I have 2 questions now… :-/
whats that new stuff in logging about transaction timers?Transaction 25 completed
STOP transaction timer
Received msg Message[36693]: class=SendData[0x13], type=Request[0x00], dest=1, callback=25, payload=19 01 00 2A
lastTransaction = null
Message is SendData
Checking outstanding transactions: 0
Last transaction: null
Not correlated with transaction
My Power Switches that worked before all stopped working. Logs say:
08:35:47.977 [INFO ] [smarthome.event.ItemCommandEvent ] - Item ‘zwave_device_15348538564_node2_switch_binary’ received command OFF
08:35:47.981 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Command received zwave:device:15348538564:node2:switch_binary --> OFF
08:35:48.002 [DEBUG] [dclass.ZWaveBinarySwitchCommandClass] - NODE 2: Creating new message for application command SWITCH_BINARY_SET
08:35:48.004 [DEBUG] [dclass.ZWaveBinarySwitchCommandClass] - NODE 2: Node doesn’t support get requests
08:35:48.006 [WARN ] [converter.ZWaveBinarySwitchConverter] - NODE 2: Generating message failed for command class = SWITCH_BINARY, endpoint = 0
08:35:48.007 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: No messages returned from converter
08:35:48.029 [INFO ] [marthome.event.ItemStateChangedEvent] - zwave_device_15348538564_node2_switch_binary changed from ON to OFF
This is a new transaction handler. It improves the handling of transactions in a more systematic way.
It’s not included in the current version yet so I guess you are using a snapshot from cloudbees rather than the official nightly build. If you find any issues, then please let me know.
Please can you advise exactly what version of the code you are using. It seems from your comment above that you are using a test version and I need to know what this is.
Another point, I don’t think that the fact that your switch isn’t working is anything to do with what you show in the log. The log shows that the command is being created ok - without more log info we don’t know if it got sent, but it otherwise looks ok.
I basically use @xsnrg Jims script. This upgrades OH2 to the latest nightly and wipes all bindgins etc.
On next startup all these are pulled aswell as current nightly
Hmm - strange. It seems something is pulling in snapshots from PR builds, and not just the nightly snapshot, which is a bit of a pain. I suspect it’s not the script, but probably cloudbees is publishing the PR builds - I’ll have a look at the cloudbees configuration to see if I can stop this.
@kai it seems that CI is deploying the PR snapshots which is a bit of a pain. In the cloudbees config there only seems to be an option to build PRs - I’d assumed it wouldn’t deploy anything that wasn’t from master as otherwise any PR request would be deployed as soon as the request is made, but it seems from this conversation that this might not be the case.
What type of switches are they? Also, do you still see the same message in the log about not creating the GET message (GET messages not supported)? I guess so, so I don’t think anything changed.
as always the Devolo fully works the PAN11 can be switched on / off again but the metering does not work. But thats now like this for as long as I can remember:
