Hello everybody
I´m currently use openhab1. Now i want upgrade to version 2b4. I want to configure all my items etc in textfiles like openhab1.
I create the textfile homematic.things
Bridge homematic:bridge:ccu [ gatewayAddress="192.168.1.XXX" ] {
Thing HG-HM-Sec-SC2 MEQ1XXXX5 "Test1" @ "Location"
Thing HG-HM-Sec-SC2 MEQ1XXXX5 "Test2" @ "Location"
Thing HG-HM-Sec-SC2 MEQ1XXXX5 "Test3" @ "Location"
Thing HG-HM-CC-RT-DN MEQ0XXXX5 "Test4" @ "Location"
Thing HG-HM-CC-RT-DN MEQ0XXXX5 "Test5" @ "Location"
Thing HG-HM-CC-RT-DN MEQ0XXXX5 "Test6" @ "Location"
After that i create my homematic.items like
Number gDG_Wohnzimmer_Fenster_Status "Wohnzimmer - Fenster-Status [MAP(HM-SEC-SC-2.map):%d]" <"rollershutter-0"> (gDG_Wohnzimmer) { channel="homematic:HG-HM-Sec-SC-2:ccu:MEQ1XXXX5:1#STATE" }
Number gDG_Wohnzimmer_Fenster_Batterie "Wohnzimmer - Fenster-Batterie [MAP(HM-SEC-SC-2_BAT.map):%d]" <"rollershutter-0"> (gDG_Wohnzimmer) { channel="homematic:HG-HM-Sec-SC-2:ccu:MEQ1XXXX5:1#LOWBAT" }
Number gDG_Wohnzimmer_Fenster_Fehler "Wohnzimmer - Fenster-Fehler [MAP(HM-SEC-SC-2_ERROR.map):%d]" <"rollershutter-0"> (gDG_Wohnzimmer) { channel="homematic:HG-HM-Sec-SC-2:ccu:MEQ1XXXX5:1#ERROR" }
But i get this error on Log:
17:17:00.713 [ERROR] [ematic.handler.HomematicThingHandler] - Could not update t
hing homematic:HG-HM-CC-RT-DN:ccu:MEQ1XXXX5. Most likely because it is read-onl
y.
java.lang.IllegalStateException: Could not update thing homematic:HG-HM-CC-RT-DN
:ccu:MEQ0802575. Most likely because it is read-only.
at org.eclipse.smarthome.core.thing.internal.ThingManager$1.thingUpdated
(ThingManager.java:237)[105:org.eclipse.smarthome.core.thing:0.9.0.201610220816]
at org.eclipse.smarthome.core.thing.binding.BaseThingHandler.updateConfi
guration(BaseThingHandler.java:469)[105:org.eclipse.smarthome.core.thing:0.9.0.2
01610220816]
at org.openhab.binding.homematic.handler.HomematicThingHandler.initializ
e(HomematicThingHandler.java:101)[196:org.openhab.binding.homematic:2.0.0.201610
221219]
at org.eclipse.smarthome.core.thing.binding.BaseThingHandler.thingUpdate
d(BaseThingHandler.java:183)[105:org.eclipse.smarthome.core.thing:0.9.0.20161022
0816]
at org.openhab.binding.homematic.handler.HomematicBridgeHandler.updateTh
ing(HomematicBridgeHandler.java:213)[196:org.openhab.binding.homematic:2.0.0.201
610221219]
at org.openhab.binding.homematic.handler.HomematicBridgeHandler.reloadDe
viceValues(HomematicBridgeHandler.java:291)[196:org.openhab.binding.homematic:2.
0.0.201610221219]
at org.openhab.binding.homematic.internal.communicator.AbstractHomematic
Gateway.triggerDeviceValuesReload(AbstractHomematicGateway.java:463)[196:org.ope
nhab.binding.homematic:2.0.0.201610221219]
at org.openhab.binding.homematic.handler.HomematicBridgeHandler.reloadAl
lDeviceValues(HomematicBridgeHandler.java:302)[196:org.openhab.binding.homematic
at org.openhab.binding.homematic.handler.HomematicBridgeHandler.onServer
Restart(HomematicBridgeHandler.java:252)[196:org.openhab.binding.homematic:2.0.0
.201610221219]
Gateway$EventTrackerThread.run(AbstractHomematicGateway.java:739)[196:org.openha
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)[:
1.8.0_92]
at java.util.concurrent.FutureTask.runAndReset(Unknown Source)[:1.8.0_92
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.
access$301(Unknown Source)[:1.8.0_92]
run(Unknown Source)[:1.8.0_92]
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)[:1.
8.0_92]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)[:1
.8.0_92]
at java.lang.Thread.run(Unknown Source)[:1.8.0_92]
What´s wrong ?
