I need help, I upgraded from openhab2 to openhab3 on my raspberry pi running openhabian. Then it failed to start. So after some googling i figured out that i need java11. Ok installed that using the config tool. Installed fine (java -version shows it is good). But still it is not working.
Seems to be in a restart loop or something (see below).
Maybe it is a permission issue? The “fix permissions” option also fails in the config tool.
Any idea how to fix?
Thank you,
Ramon
openhabian@openHABianPi:~ $ sudo /bin/systemctl status openhab.service
● openhab.service - openHAB instance, reachable at http://openHABianPi:8080
Loaded: loaded (/usr/lib/systemd/system/openhab.service; enabled; vendor preset: enabled)
Drop-In: /etc/systemd/system/openhab.service.d
└─override.conf
Active: active (running) since Fri 2021-03-26 21:46:33 CET; 13s ago
Docs: https://www.openhab.org/docs/
https://community.openhab.org
Process: 17484 ExecStop=/usr/share/openhab/runtime/bin/karaf stop (code=exited, status=1/FAILURE)
Main PID: 17602 (karaf)
Tasks: 31 (limit: 4915)
CGroup: /system.slice/openhab.service
├─17602 /bin/sh /usr/share/openhab/runtime/bin/karaf debug
└─17700 /usr/bin/java -agentlib:jdwp=transport=dt_socket,server=y,suspend=n,address=*:5005 -Dopenhab.home=/usr/share/openhab -Dopenhab.conf=/etc/openhab -Dopenhab.runtime=/usr/sh
Mar 26 21:46:42 openHABianPi karaf[17602]: ___ ___ ___ ___ | | | | / \ | __ )
Mar 26 21:46:42 openHABianPi karaf[17602]: / _ \ / _ \ / _ \ / _ \ | |_| | / _ \ | _ \
Mar 26 21:46:42 openHABianPi karaf[17602]: | (_) | (_) | __/| | | || _ | / ___ \ | |_) )
Mar 26 21:46:42 openHABianPi karaf[17602]: \___/| __/ \___/|_| |_||_| |_|/_/ \_\|____/
Mar 26 21:46:42 openHABianPi karaf[17602]: |_| 3.0.1 - Release Build
Mar 26 21:46:42 openHABianPi karaf[17602]: [1B blob data]
Mar 26 21:46:42 openHABianPi karaf[17602]: Use '<tab>' for a list of available commands
Mar 26 21:46:42 openHABianPi karaf[17602]: and '[cmd] --help' for help on a specific command.
Mar 26 21:46:42 openHABianPi karaf[17602]: To exit, use '<ctrl-d>' or 'logout'.
Mar 26 21:46:44 openHABianPi karaf[17602]: openhab>
└─override.conf
Active: active (running) since Fri 2021-03-26 21:48:53 CET; 1s ago
Process: 18931 ExecStop=/usr/share/openhab/runtime/bin/karaf stop (code=exited, status=1/FAILURE)
Main PID: 19050 (karaf)
Tasks: 3 (limit: 4915)
├─19050 /bin/sh /usr/share/openhab/runtime/bin/karaf debug
└─19148 /usr/bin/java -agentlib:jdwp=transport=dt_socket,server=y,suspend=n,address=*:5005 -Dopenhab.home=/usr/share/openhab -Dopenhab.conf=/etc/openhab -Dopenhab.runtime=/usr/sh
Mar 26 21:48:53 openHABianPi systemd[1]: Started openHAB instance, reachable at http://openHABianPi:8080.
└─override.conf
Active: activating (auto-restart) (Result: exit-code) since Fri 2021-03-26 21:50:13 CET; 4s ago
Process: 19883 ExecStop=/usr/share/openhab/runtime/bin/karaf stop (code=exited, status=1/FAILURE)
Process: 19669 ExecStart=/usr/share/openhab/runtime/bin/karaf ${OPENHAB_STARTMODE} (code=exited, status=0/SUCCESS)
Main PID: 19669 (code=exited, status=0/SUCCESS)
Mar 26 21:50:13 openHABianPi systemd[1]: openhab.service: Control process exited, code=exited status=1
Mar 26 21:50:13 openHABianPi systemd[1]: openhab.service: Unit entered failed state.
Mar 26 21:50:13 openHABianPi systemd[1]: openhab.service: Failed with result 'exit-code'.
openhabian@openHABianPi:~ $ tail -f /var/log/openhab/openhab.log
at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:1004) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.apache.karaf.util.tracker.BaseActivator.register(BaseActivator.java:425) ~[bundleFile:?]
at org.apache.karaf.util.tracker.BaseActivator.register(BaseActivator.java:413) ~[bundleFile:?]
at org.apache.karaf.features.internal.osgi.Activator.doStart(Activator.java:180) ~[bundleFile:?]
at org.apache.karaf.util.tracker.BaseActivator.run(BaseActivator.java:312) [bundleFile:?]
tail of /var/log/openhab/openhab.log does not show enough information what is shown in the first lines of the error block that you listed ?
This is the entire log:
openhabian@openHABianPi:~ $ cat /var/log/openhab/openhab.log
2021-03-26 22:44:42.422 [WARN ] [org.jline ] - Unable to create a system terminal, creating a dumb terminal (enable debug logging for more information)
2021-03-26 22:44:46.285 [WARN ] [raf.features.internal.osgi.Activator] - Error starting activator
java.lang.IllegalStateException: BundleContext is no longer valid
at org.eclipse.osgi.internal.framework.BundleContextImpl.checkValid(BundleContextImpl.java:989) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:468) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:487) ~[org.eclipse.osgi-3.12.100.jar:?]
what is shown by sudo journalctl -u openhab ?
A lot of repeating the same thing, this is part of the log:
Mar 26 20:59:40 openHABianPi karaf[14300]: Listening for transport dt_socket at address: 5005
Mar 26 20:59:51 openHABianPi karaf[14300]: [1B blob data]
Mar 26 20:59:51 openHABianPi karaf[14300]: _ _ _ ____
Mar 26 20:59:51 openHABianPi karaf[14300]: ___ ___ ___ ___ | | | | / \ | __ )
Mar 26 20:59:51 openHABianPi karaf[14300]: / _ \ / _ \ / _ \ / _ \ | |_| | / _ \ | _ \
Mar 26 20:59:51 openHABianPi karaf[14300]: | (_) | (_) | __/| | | || _ | / ___ \ | |_) )
Mar 26 20:59:51 openHABianPi karaf[14300]: \___/| __/ \___/|_| |_||_| |_|/_/ \_\|____/
Mar 26 20:59:51 openHABianPi karaf[14300]: |_| 3.0.1 - Release Build
Mar 26 20:59:51 openHABianPi karaf[14300]: Use '<tab>' for a list of available commands
Mar 26 20:59:51 openHABianPi karaf[14300]: and '[cmd] --help' for help on a specific command.
Mar 26 20:59:51 openHABianPi karaf[14300]: To exit, use '<ctrl-d>' or 'logout'.
Mar 26 20:59:55 openHABianPi karaf[14300]: openhab>
Mar 26 21:00:07 openHABianPi karaf[14636]: Can't connect to the container. The container is not running.
Mar 26 21:00:07 openHABianPi systemd[1]: openhab.service: Control process exited, code=exited status=1
Mar 26 21:00:07 openHABianPi systemd[1]: openhab.service: Unit entered failed state.
Mar 26 21:00:07 openHABianPi systemd[1]: openhab.service: Failed with result 'exit-code'.
Mar 26 21:00:12 openHABianPi systemd[1]: openhab.service: Service hold-off time over, scheduling restart.
Mar 26 21:00:12 openHABianPi systemd[1]: Stopped openHAB instance, reachable at http://openHABianPi:8080.
Mar 26 21:00:12 openHABianPi systemd[1]: Started openHAB instance, reachable at http://openHABianPi:8080.
Mar 26 21:00:14 openHABianPi karaf[14745]: Listening for transport dt_socket at address: 5005
Mar 26 21:00:17 openHABianPi systemd[1]: Stopping openHAB instance, reachable at http://openHABianPi:8080...
Mar 26 21:00:20 openHABianPi karaf[14866]: Can't connect to the container. The container is not running.
Mar 26 21:00:20 openHABianPi systemd[1]: openhab.service: Control process exited, code=exited status=1
Mar 26 21:00:36 openHABianPi systemd[1]: Stopped openHAB instance, reachable at http://openHABianPi:8080.
Mar 26 21:00:36 openHABianPi systemd[1]: openhab.service: Unit entered failed state.
Mar 26 21:00:36 openHABianPi systemd[1]: openhab.service: Failed with result 'exit-code'.
Mar 26 21:03:50 openHABianPi systemd[1]: Started openHAB instance, reachable at http://openHABianPi:8080.
Mar 26 21:03:52 openHABianPi karaf[15684]: Listening for transport dt_socket at address: 5005
Mar 26 21:03:53 openHABianPi karaf[15684]: java.lang.RuntimeException: /var/log/openhab/openhab.log (Permission denied)
Mar 26 21:03:53 openHABianPi karaf[15684]: at org.apache.karaf.main.util.BootstrapLogManager.getDefaultHandlerInternal(BootstrapLogManager.java:102)
Mar 26 21:03:53 openHABianPi karaf[15684]: at org.apache.karaf.main.util.BootstrapLogManager.getDefaultHandlersInternal(BootstrapLogManager.java:137)
Mar 26 21:03:53 openHABianPi karaf[15684]: at org.apache.karaf.main.util.BootstrapLogManager.getDefaultHandlers(BootstrapLogManager.java:70)
Mar 26 21:03:53 openHABianPi karaf[15684]: at org.apache.karaf.main.util.BootstrapLogManager.configureLogger(BootstrapLogManager.java:75)
Mar 26 21:03:53 openHABianPi karaf[15684]: at org.apache.karaf.main.Main.launch(Main.java:244)
Mar 26 21:03:53 openHABianPi karaf[15684]: at org.apache.karaf.main.Main.main(Main.java:178)
Mar 26 21:03:53 openHABianPi karaf[15684]: Caused by: java.io.FileNotFoundException: /var/log/openhab/openhab.log (Permission denied)
Mar 26 21:03:53 openHABianPi karaf[15684]: at java.base/java.io.FileOutputStream.open0(Native Method)
Mar 26 21:03:53 openHABianPi karaf[15684]: at java.base/java.io.FileOutputStream.open(FileOutputStream.java:298)
Mar 26 21:03:53 openHABianPi karaf[15684]: at java.base/java.io.FileOutputStream.<init>(FileOutputStream.java:237)
Mar 26 21:03:53 openHABianPi karaf[15684]: at org.apache.karaf.main.util.BootstrapLogManager$SimpleFileHandler.open(BootstrapLogManager.java:193)
Mar 26 21:03:53 openHABianPi karaf[15684]: at org.apache.karaf.main.util.BootstrapLogManager$SimpleFileHandler.<init>(BootstrapLogManager.java:182)
Mar 26 21:03:53 openHABianPi karaf[15684]: at org.apache.karaf.main.util.BootstrapLogManager.getDefaultHandlerInternal(BootstrapLogManager.java:100)
Mar 26 21:03:53 openHABianPi karaf[15684]: ... 5 more
Mar 26 21:03:56 openHABianPi karaf[15684]: java.lang.RuntimeException: /var/log/openhab/openhab.log (Permission denied)
Mar 26 21:03:56 openHABianPi karaf[15684]: at org.apache.karaf.main.util.BootstrapLogManager.getDefaultHandlerInternal(BootstrapLogManager.java:102)
Mar 26 21:03:56 openHABianPi karaf[15684]: at org.apache.karaf.main.util.BootstrapLogManager.getDefaultHandlersInternal(BootstrapLogManager.java:137)
Mar 26 21:03:56 openHABianPi karaf[15684]: at org.apache.karaf.main.util.BootstrapLogManager.getDefaultHandlers(BootstrapLogManager.java:70)
Mar 26 21:03:56 openHABianPi karaf[15684]: at org.apache.karaf.main.util.BootstrapLogManager.configureLogger(BootstrapLogManager.java:75)
Mar 26 21:03:56 openHABianPi karaf[15684]: at org.apache.karaf.main.KarafActivatorManager.<init>(KarafActivatorManager.java:48)
Mar 26 21:03:56 openHABianPi karaf[15684]: at org.apache.karaf.main.Main.launch(Main.java:280)
Mar 26 21:03:56 openHABianPi karaf[15684]: at org.apache.karaf.main.Main.main(Main.java:178)
Mar 26 21:03:56 openHABianPi karaf[15684]: Caused by: java.io.FileNotFoundException: /var/log/openhab/openhab.log (Permission denied)
Mar 26 21:03:56 openHABianPi karaf[15684]: at java.base/java.io.FileOutputStream.open0(Native Method)
Mar 26 21:03:56 openHABianPi karaf[15684]: at java.base/java.io.FileOutputStream.open(FileOutputStream.java:298)
Mar 26 21:03:56 openHABianPi karaf[15684]: at java.base/java.io.FileOutputStream.<init>(FileOutputStream.java:237)
Mar 26 21:03:56 openHABianPi karaf[15684]: at org.apache.karaf.main.util.BootstrapLogManager$SimpleFileHandler.open(BootstrapLogManager.java:193)
Mar 26 21:03:56 openHABianPi karaf[15684]: at org.apache.karaf.main.util.BootstrapLogManager$SimpleFileHandler.<init>(BootstrapLogManager.java:182)
Mar 26 21:03:56 openHABianPi karaf[15684]: at org.apache.karaf.main.util.BootstrapLogManager.getDefaultHandlerInternal(BootstrapLogManager.java:100)
Mar 26 21:03:56 openHABianPi karaf[15684]: ... 6 more
Mar 26 21:03:57 openHABianPi karaf[15684]: java.lang.RuntimeException: /var/log/openhab/openhab.log (Permission denied)
Mar 26 21:03:57 openHABianPi karaf[15684]: at org.apache.karaf.main.util.BootstrapLogManager.getDefaultHandlerInternal(BootstrapLogManager.java:102)
Mar 26 21:03:57 openHABianPi karaf[15684]: at org.apache.karaf.main.util.BootstrapLogManager.getDefaultHandlersInternal(BootstrapLogManager.java:137)
Mar 26 21:03:57 openHABianPi karaf[15684]: at org.apache.karaf.main.util.BootstrapLogManager.getDefaultHandlers(BootstrapLogManager.java:70)
Mar 26 21:03:57 openHABianPi karaf[15684]: at org.apache.karaf.main.util.BootstrapLogManager.configureLogger(BootstrapLogManager.java:75)
Mar 26 21:03:57 openHABianPi karaf[15684]: at org.apache.karaf.main.lock.SimpleFileLock.<init>(SimpleFileLock.java:40)
Mar 26 21:03:57 openHABianPi karaf[15684]: at java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
Mar 26 21:03:57 openHABianPi karaf[15684]: at java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62)
Mar 26 21:03:57 openHABianPi karaf[15684]: at java.base/jdk.internal.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
Mar 26 21:03:57 openHABianPi karaf[15684]: at java.base/java.lang.reflect.Constructor.newInstance(Constructor.java:490)
Mar 26 21:03:57 openHABianPi karaf[15684]: at org.apache.karaf.main.Main.createLock(Main.java:516)
Mar 26 21:03:57 openHABianPi karaf[15684]: at org.apache.karaf.main.Main.doMonitor(Main.java:388)
Mar 26 21:03:57 openHABianPi karaf[15684]: at org.apache.karaf.main.Main.access$100(Main.java:74)
Mar 26 21:03:57 openHABianPi karaf[15684]: at org.apache.karaf.main.Main$3.run(Main.java:377)
Mar 26 21:03:57 openHABianPi karaf[15684]: Caused by: java.io.FileNotFoundException: /var/log/openhab/openhab.log (Permission denied)
Mar 26 21:03:57 openHABianPi karaf[15684]: at java.base/java.io.FileOutputStream.open0(Native Method)
Mar 26 21:03:57 openHABianPi karaf[15684]: at java.base/java.io.FileOutputStream.open(FileOutputStream.java:298)
Mar 26 21:03:57 openHABianPi karaf[15684]: at java.base/java.io.FileOutputStream.<init>(FileOutputStream.java:237)
Mar 26 21:03:57 openHABianPi karaf[15684]: at org.apache.karaf.main.util.BootstrapLogManager$SimpleFileHandler.open(BootstrapLogManager.java:193)
Mar 26 21:03:57 openHABianPi karaf[15684]: at org.apache.karaf.main.util.BootstrapLogManager$SimpleFileHandler.<init>(BootstrapLogManager.java:182)
Mar 26 21:03:57 openHABianPi karaf[15684]: at org.apache.karaf.main.util.BootstrapLogManager.getDefaultHandlerInternal(BootstrapLogManager.java:100)
Mar 26 21:03:57 openHABianPi karaf[15684]: ... 12 more
Mar 26 21:04:00 openHABianPi karaf[15684]: org.ops4j.pax.logging.pax-logging-api [log4j2] ERROR : RollingFileManager (/var/log/openhab/openhab.log) java.io.FileNotFoundException: /var/log/o
Mar 26 21:04:00 openHABianPi karaf[15684]: java.io.FileNotFoundException: /var/log/openhab/openhab.log (Permission denied)
Mar 26 21:04:00 openHABianPi karaf[15684]: at java.base/java.io.FileOutputStream.open0(Native Method)
you stated that running “fix permissions” ends with an error message. what is the exact behvior / message ?
Its option 14 but the actual error message says the 10
it looks like the permission of directory /var/log/openhab is not correct.
What is the permission of that directory and the file in case the file is available:
ls -ld /var/log/openhab /var/log/openhab/openhab.log
both need to be owned by openhab:openhab ( which means user:group )
it does look a bit odd especially the readme.txt why does that have “x”?!? Also the directory apparantly is not owned correctly. I changed that now but it does
openhabian@openHABianPi:~ $ ls -ld /var/log/openhab /var/log/openhab/openhab.log
drwxrwxr-x 2 openhab openhabian 4096 Mar 27 09:13 /var/log/openhab
-rw-r--r-- 1 openhab openhab 1646 Mar 27 09:14 /var/log/openhab/openhab.log
openhabian@openHABianPi:~ $ ls -l /var/log/openhab/
total 32
-rw-rw-rw- 1 openhab openhab 0 Mar 25 18:06 audit.log
-rw-rw-rw- 1 openhab openhab 0 Mar 25 18:06 events.log
-rw-r--r-- 1 openhab openhab 178 Mar 27 09:15 openhab.log
-rw-r--r-- 1 openhab openhab 1626 Mar 27 09:12 openhab.log.1
-rw-r--r-- 1 openhab openhab 1646 Mar 27 09:13 openhab.log.2
-rw-r--r-- 1 openhab openhab 1646 Mar 27 09:13 openhab.log.3
-rw-r--r-- 1 openhab openhab 1646 Mar 27 09:14 openhab.log.4
-rw-r--r-- 1 openhab openhab 1626 Mar 27 09:14 openhab.log.5
-rw-r--r-- 1 openhab openhab 1646 Mar 27 09:14 openhab.log.6
-rw-r--r-- 1 openhab openhab 1646 Mar 27 09:15 openhab.log.7
-rwxrwxr-x 1 openhab openhab 0 Jan 27 21:42 Readme.txt
Im guessing its related to the “BundleContext is no longer valid”
2021-03-27 09:27:05.134 [WARN ] [org.jline ] - Unable to create a system terminal, creating a dumb terminal (enable debug logging for more information)
2021-03-27 09:27:09.053 [WARN ] [raf.features.internal.osgi.Activator] - Error starting activator
now i get these type of errors in /var/log/openhab/openhab.log
2021-03-27 12:21:46.580 [SEVERE] [org.apache.karaf.main.Main] - Could not launch framework
java.lang.RuntimeException: Error initializing storage.
at org.eclipse.osgi.internal.framework.EquinoxContainer.<init>(EquinoxContainer.java:70)
at org.eclipse.osgi.launch.Equinox.<init>(Equinox.java:31)
at org.eclipse.osgi.launch.EquinoxFactory.newFramework(EquinoxFactory.java:24)
at org.apache.karaf.main.Main.launch(Main.java:256)
Caused by: java.io.IOException: Unable to create lock manager.
at org.eclipse.osgi.storagemanager.StorageManager.open(StorageManager.java:698)
at org.eclipse.osgi.storage.Storage.getChildStorageManager(Storage.java:1776)
at org.eclipse.osgi.storage.Storage.getInfoInputStream(Storage.java:1793)
at org.eclipse.osgi.storage.Storage.<init>(Storage.java:132)
at org.eclipse.osgi.storage.Storage.createStorage(Storage.java:85)
at org.eclipse.osgi.internal.framework.EquinoxContainer.<init>(EquinoxContainer.java:68)
... 4 more
2021-03-27 12:21:58.146 [SEVERE] [org.apache.karaf.main.Main] - Could not launch framework
... 4 more
Thank you for the suggestion but that did not seem to help. Still the same problem.
How do i remove the whole thing and reinstall? Maybe that helps
openhabian@openHABianPi:/ $ cat /var/log/openhab/openhab.log
2021-03-27 15:00:10.326 [WARN ] [org.jline ] - Unable to create a system terminal, creating a dumb terminal (enable debug logging for more information)
2021-03-27 15:00:13.818 [WARN ] [raf.features.internal.osgi.Activator] - Error starting activator
