My configuration:
Release = Raspbian GNU/Linux 10 (buster)
Kernel = Linux 4.19.97+
Platform = Raspberry Pi Model B Rev 2
Uptime = 0 day(s). 0:54:14
CPU Usage = 12.75% avg over 2 cpu(s) (1 core(s) x 1 socket(s))
CPU Load = 1m: 0.24, 5m: 0.79, 15m: 1.70
Memory = Free: 0.02GB (6%), Used: 0.44GB (94%), Total: 0.46GB
Swap = Free: 0.08GB (91%), Used: 0.00GB (9%), Total: 0.09GB
Root = Free: 11.33GB (82%), Used: 2.37GB (18%), Total: 14.32GB
Updates = 0 apt updates available.
Sessions = 1 session(s)
Processes = 75 running processes of 32768 maximum processes
When rebooting it seems that the first run process keeps repeating. Openhabian seems to be operating correctly when it finally runs but each reboot takes about one hour for it to operate properly.
There were two errors generated in the log file:
Setting timezone based on IP geolocation... FAILED
Waiting for openHAB to become ready...1..2..3..4..5..6..7..8..9..10..11..12..13..14..15..16..17..18..19..20..failed.
The log file ends immediately after the last “failed” entry. The former error I assume is not a big deal but the latter error, which appears on the last line of the log file seems more important.
- What should the last of a successfully concluded log file look like?
- Is the initial script missing an important step?
- Why is the first run script repeating each time the system boots? and most importantly:
- How do I stop this reboot issue?
What I have done to try to eliminate this so far:
- Downloaded, burned and re-installed the image numerous times. Result=nada
- Tried to find any reference to this issue. Result=nada.
Any help or insights will be appreciated.
