Usage of new ECMA2021 Automation Scripting (GraalVM)
Sorry about hijacking this thread, but how did you manage to run it at all?
I’m running 3.2.0.M1-debian in Docker and getting this:
2021-08-02 21:57:49.315 [ERROR] [ipt.internal.ScriptEngineManagerImpl] - Error during evaluation of script 'file:/openhab/conf/automation/jsr223/javascript/personal/testRule.js': /openhab/conf/automation/jsr223/javascript/personal/testRule.js:1:0 Expected an operand but found const
const ohj = require("ohj");
^ in /openhab/conf/automation/jsr223/javascript/personal/testRule.js at line number 1 at column number 0
It looks like there is no ES6+ support. What do I need to do to install/activate GraalJS?
A minor update here. After unzipping the ohj-support you also need to take it out of the folder. I got caught with the folder name being the same as the JAR so thought that was it. After taking the actual JAR out of the folder to the root of the add ons directory we are in business. (lockdown has fried my brain).
An additional tip I worked out is that the logger has a hard coded prefix of script.js so for the messages to show in the openhab log you need to update the openhab console with
log:set debug script.js
Happy to write a beginners guide based on my setup from today collecting all the above information
For the record, I filed several issues on jsscripting. The import issue (PolyglotException: TypeError: Access to host class) discussed in this issue here: [jsscripting] Unable to import classes from org.openhab.core · Issue #11222 · openhab/openhab-addons · GitHub
Other issues:
Imports are working now!
With the release of the 3.2.0.M4 Milestone Build the import of classes from org.openhab.core works, as this Issue #11222 was closed by PR #11400.
Please note
The folder openhab-conf/automation/lib/javascript/personal must exist, without that folder the Add-On throws errors.
I have created this Issue #11616 to either mention that in the docs or to create that folder on openHAB start-up/Add-On installation.
Small guide for GraalVM
I have completed a few tests and created a small guide which is hosted at florian-h05/openhab-addons.
Table Of Contents of the Guide
Excellent summary! Would be great if you could consider improving the jsscripting addon docs with those.
In the guide you state
Please note that toString() is supported, but toBigDecimal()is not working anymore.
What does this mean exactly? What is the error and is there already a github issue filed?
Thank you, of course I can add those to the jsscripting addon docs.
I thought that the conversion toBigDecimal() is not working anymore (I used to use it when getting item states to make sure they are number and not string), but I checked it again and it is working.
So it does not mean something, I wrote it because I thought it does not work but I just had a typo on my tests.
I have updated my guide to fix my misconception, next I will work on adding it to the addon docs.
I have created a PR on GitHub for the docs.
Before going to too much effort on the docs front, be sure to review what’s going on at GraalVM JavaScript replaces Nashorn, breaking Blockly and existing Nashorn rules · Issue #2433 · openhab/openhab-core · GitHub. Work is going on to address several related issues in that one issue:
  • installation of the helper libraries with the add-on which will; potentially change the docs significantly
  • working in the UI without requiring too many imports
  • migration of Nashorn script to GraalVM JS scripts.
Thank you for that hint, my docs were already finished yesterday.
I read that discussion and it clearly seems that the docs have to be rewritten during these issues are addressed and resolved.
I think my docs are a good first version to just show a few basics that are working currently on the 3.2.0.M4 Milestone Release.
Hi guys,
I know, it’s little out of this topic, but let me ask. I’m using the DSL rules (1.5 years) from the beginning, but I don’t really like it. I have decided that the next project I will build into my system will be on JS basis. I thought it will be 1hours to get familiar with the new API calls(I already have JS experience), then I can start developing the code.
Unfortunately, I’m spending the 3rd or 4th night to find out what to do, to get the JS stuff even running. I’m fully confused about everything. I’m running on OH 3.1. Do I need to install the “JSScripting” automation add-on? Which JS engine and library to use? I have started with this guide (Installation — openHAB Helper Libraries documentation), but the helloWorld.js example is not working. Then came here to this topic, where you are discussing a new engine with a new (unofficial) library.
It seems to me, that DSL is the “official” scripting and all the others are only hackings, to get it there, but except of some hackers or pioneers nobody is (able) using it. Based on what I see, the JS is something which would get more focus in the later versions, but it needs some time …
Am I right? Or can someone point me to the right direction?
Thanks!
There are two JavaScript Engines. The default one that comes with openHAB is called Nashorn and it implements ECMAScript 5.1.
The add-on is a completely different JavaScript which implements ECMAScript 2021 (I think, at least something way more recent).
The two are pretty different in usage. The two have completely different helper libraries. In general, the two are not compatible with each other. If you have the add-on installed, scripts written for Nashorn will not work.
A few posts up there is a thread where work is going on to rectify that and make GraalVM JS easier to use. But if you don’t want to wait, see @florian-h05’s documentation. If you want to use Nashorn use the link you posted already.
Thanks for the quick reaction Rich. The posts, you created a year ago (OH 3 Examples: Writing and using JavaScript Libraries in MainUI created Rules) is then for Nashorn?
Yes, GraalVM hasn’t been around very long. Pretty much anything I’ve posted thus far is for Nashorn. Though soon I’m going to switch over to GraalVM JS. I just need some time to do it.
