I’m not a Groovy specialist, implemented Java-script part for this Bundle. So this is untested:
//PersistenceExtensions
peExample = pe.historicState( ir.getItem(“Wintergarten_Temperatur”), DateTime.now().minusDays(7))
self.logger.info(“Wintergarten_Temperatur last Week: {}”, peExample)
for using Javascript, you only have to copy from “distribution-X.X.X-addons.zip” copy “org.openhab.core.jsr223-X.X.X.jar” to [PATH TO YOUR OPENHAB]\addons.
I’m giving this another go and still no luck so some help is much appreciated!
The Groovy example on https://github.com/openhab/openhab/wiki/Jsr223-Script-Engine references PersistenceExtensions as a script global. However, this global isn’t available, so I don’t see how this example can correctly work. (cf. org.openhab.core.jsr223.internal.engine.scriptmanager.Script#initializeSciptGlobals).
I’m getting closer by instantiating PersistenceExtensions myself in the rule, but here I’m facing the error below which is specific to Groovy I guess. Additionally, this requires extending the classpath in the startup script.
groovy.lang.MissingMethodException: No signature of method: org.openhab.core.persistence.extensions.PersistenceExtensions.changedSince() is applicable for argument types: (org.openhab.core.items.GroupItem, org.joda.time.DateTime, java.lang.String) values: [Trap (Type=GroupItem, Members=1, State=ON), 2015-10-27T18:07:09.019+01:00, …]
Possible solutions: changedSince(org.openhab.core.items.Item, org.joda.time.base.AbstractInstant, java.lang.String), changedSince(org.openhab.core.items.Item, org.joda.time.base.AbstractInstant)
at org.codehaus.groovy.runtime.ScriptBytecodeAdapter.unwrap(ScriptBytecodeAdapter.java:58) ~[groovy-all-2.4.5.jar:2.4.5]
at org.codehaus.groovy.runtime.callsite.PojoMetaClassSite.call(PojoMetaClassSite.java:49) ~[groovy-all-2.4.5.jar:2.4.5]
at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:141) ~[groovy-all-2.4.5.jar:2.4.5]
at AutoOffRule.execute(Script1.groovy:34) ~[na:na]
at org.openhab.core.jsr223.internal.engine.RuleExecutionRunnable.run(RuleExecutionRunnable.java:36) ~[na:na]
at java.lang.Thread.run(Thread.java:745) [na:1.8.0_31]
Rewrote my rule with Javascript (on Nashorn). Finally bumped against a similar error:
java.lang.RuntimeException: java.lang.NoSuchMethodException: None of the fixed arity signatures [(org.openhab.core.items.Item, org.joda.time.base.AbstractInstant)] of method org.openhab.core.persistence.extensions.PersistenceExtensions.changedSince match the argument types [org.openhab.core.items.GroupItem, org.joda.time.DateTime]
at jdk.nashorn.javaadapters.java.util.function.Consumer.accept(Unknown Source) ~[na:na]
at java.util.ArrayList.forEach(ArrayList.java:1249) ~[na:1.8.0_31]
at jdk.nashorn.internal.scripts.Script$^eval_.L:13(:14) ~[na:na]
at org.openhab.core.jsr223.internal.shared.Rule$$NashornJavaAdapter.execute(Unknown Source) ~[na:na]
I’m getting following exception when loading the provided script on my instance (openHAB 1.7.1 on jdk1.8.0_65/Windows 7).
Any idea what might be the cause? On which openHAB, JVM/JDK, OS are you running? Can you provide your start.bat/start.sh?
2015-11-24 18:02:04.582 [INFO ] [o.o.c.j.i.e.s.ScriptManager ] - Available engines:
2015-11-24 18:02:04.612 [INFO ] [o.o.c.j.i.e.s.ScriptManager ] - Oracle Nashorn
2015-11-24 18:02:04.612 [INFO ] [o.o.c.j.i.e.s.ScriptManager ] - Groovy Scripting Engine
2015-11-24 18:02:04.612 [INFO ] [o.c.j.i.e.scriptmanager.Script] - Loading Script AutoOff.js
2015-11-24 18:02:05.142 [ERROR] [o.o.c.j.i.e.s.ScriptManager ] - script exception
javax.script.ScriptException: TypeError: interface org.openhab.core.jsr223.internal.shared.Rule is not a function in at line number 9
at jdk.nashorn.api.scripting.NashornScriptEngine.throwAsScriptException(NashornScriptEngine.java:467) ~[nashorn.jar:na]
at jdk.nashorn.api.scripting.NashornScriptEngine.evalImpl(NashornScriptEngine.java:451) ~[nashorn.jar:na]
at jdk.nashorn.api.scripting.NashornScriptEngine.evalImpl(NashornScriptEngine.java:403) ~[nashorn.jar:na]
at jdk.nashorn.api.scripting.NashornScriptEngine.evalImpl(NashornScriptEngine.java:399) ~[nashorn.jar:na]
at jdk.nashorn.api.scripting.NashornScriptEngine.eval(NashornScriptEngine.java:150) ~[nashorn.jar:na]
at javax.script.AbstractScriptEngine.eval(Unknown Source) ~[na:1.8.0_65]
at org.openhab.core.jsr223.internal.engine.scriptmanager.Script.loadScript(Script.java:79) ~[bundlefile:na]
at org.openhab.core.jsr223.internal.engine.scriptmanager.Script.(Script.java:67) ~[bundlefile:na]
at org.openhab.core.jsr223.internal.engine.scriptmanager.ScriptManager.loadScript(ScriptManager.java:86) [bundlefile:na]
at org.openhab.core.jsr223.internal.engine.scriptmanager.ScriptManager.loadScripts(ScriptManager.java:79) [bundlefile:na]
at org.openhab.core.jsr223.internal.engine.scriptmanager.ScriptManager.(ScriptManager.java:68) [bundlefile:na]
at org.openhab.core.jsr223.internal.engine.Jsr223Engine.activate(Jsr223Engine.java:71) [bundlefile:na]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[na:1.8.0_65]
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) ~[na:1.8.0_65]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) ~[na:1.8.0_65]
at java.lang.reflect.Method.invoke(Unknown Source) ~[na:1.8.0_65]
at org.eclipse.equinox.internal.ds.model.ServiceComponent.activate(ServiceComponent.java:235) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.activate(ServiceComponentProp.java:146) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.build(ServiceComponentProp.java:345) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.ds.InstanceProcess.buildComponent(InstanceProcess.java:620) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.ds.InstanceProcess.buildComponents(InstanceProcess.java:197) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.ds.Resolver.buildNewlySatisfied(Resolver.java:473) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.ds.Resolver.enableComponents(Resolver.java:217) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.ds.SCRManager.performWork(SCRManager.java:816) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.ds.SCRManager$QueuedJob.dispatch(SCRManager.java:783) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.ds.WorkThread.run(WorkThread.java:89) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.util.impl.tpt.threadpool.Executor.run(Executor.java:70) [org.eclipse.equinox.util_1.0.400.v20120917-192807.jar:na]
Caused by: jdk.nashorn.internal.runtime.ECMAException: TypeError: interface org.openhab.core.jsr223.internal.shared.Rule is not a function
at jdk.nashorn.internal.runtime.ECMAErrors.error(ECMAErrors.java:57) ~[nashorn.jar:na]
at jdk.nashorn.internal.runtime.ECMAErrors.typeError(ECMAErrors.java:213) ~[nashorn.jar:na]
at jdk.nashorn.internal.runtime.ECMAErrors.typeError(ECMAErrors.java:185) ~[nashorn.jar:na]
at jdk.nashorn.internal.runtime.ECMAErrors.typeError(ECMAErrors.java:172) ~[nashorn.jar:na]
at jdk.nashorn.internal.runtime.linker.NashornBottomLinker.linkBean(NashornBottomLinker.java:95) ~[nashorn.jar:na]
at jdk.nashorn.internal.runtime.linker.NashornBottomLinker.getGuardedInvocation(NashornBottomLinker.java:71) ~[nashorn.jar:na]
at jdk.internal.dynalink.support.CompositeGuardingDynamicLinker.getGuardedInvocation(CompositeGuardingDynamicLinker.java:124) ~[nashorn.jar:na]
at jdk.internal.dynalink.support.LinkerServicesImpl.getGuardedInvocation(LinkerServicesImpl.java:154) ~[nashorn.jar:na]
at jdk.internal.dynalink.DynamicLinker.relink(DynamicLinker.java:253) ~[nashorn.jar:na]
at jdk.nashorn.internal.scripts.Script$^eval_.:program(:9) ~[na:na]
at jdk.nashorn.internal.runtime.ScriptFunctionData.invoke(ScriptFunctionData.java:640) ~[nashorn.jar:na]
at jdk.nashorn.internal.runtime.ScriptFunction.invoke(ScriptFunction.java:228) ~[nashorn.jar:na]
at jdk.nashorn.internal.runtime.ScriptRuntime.apply(ScriptRuntime.java:393) ~[nashorn.jar:na]
at jdk.nashorn.api.scripting.NashornScriptEngine.evalImpl(NashornScriptEngine.java:446) ~[nashorn.jar:na]
… 25 common frames omitted
For loading Java classes with Nashorn you need to start openHab with the for java 8 preferred class-loader. Therefore add the -Dorg.osgi.framework.bundle.parent=ext parameter to your start.sh or start.bat.
