Platform information:
Hardware: 64-bit 4 cores/2GB RAM/128GB HDD (This is actually a virtual machine, but these are the specs it’s been dealt)
OS: Debian Stretch (9.5)
Java Runtime Environment: Zulu 8.31.0.1-linux64
openHAB version: 2.3.0
I’ve had some problems with my rfxtrx controller reconnecting on it’s own and getting new device names etc. and after reading up on this problem I got myself a USB-hub with an external power supply. I moved both my rfxtrx and my z-stick (z-wave controller) to the hub. They both showed as offline in paperUI and the log was full of all kinds of errors, so I rebooted the whole openhab VM. Still offline. So I disconnected and reconnected the USB hub and all of a sudden everything works. Didn’t think much about this until I had to reboot the openhab VM once again and they both went offline. Disconnect/reconnect the USB devices or the hub and they come back to working order. In paperUI there are no errors, they are just “offline”. If I disconnect the devices I get the correct errors about the devices not existing. Looking at the openhab log however, there are many errors from the rfxbridge like this:
2018-09-03 13:02:48.001 [ERROR] [g.rfxcom.handler.RFXComBridgeHandler] - Error occurred: Timeout during packet read
2018-09-03 13:03:50.634 [ERROR] [g.rfxcom.handler.RFXComBridgeHandler] - Error occurred: Timeout during packet read
2018-09-03 13:05:02.056 [ERROR] [g.rfxcom.handler.RFXComBridgeHandler] - Error occurred: Timeout during packet read
2018-09-03 13:05:59.751 [ERROR] [g.rfxcom.handler.RFXComBridgeHandler] - Error occurred: Timeout during packet read
2018-09-03 13:07:00.532 [ERROR] [g.rfxcom.handler.RFXComBridgeHandler] - Error occurred during packet receiving, data: 140001025318028C2F0001031C04524658434F4
D0A
org.openhab.binding.rfxcom.internal.exceptions.RFXComException: java.lang.reflect.InvocationTargetException
at org.openhab.binding.rfxcom.internal.messages.RFXComMessageFactory.createMessage(RFXComMessageFactory.java:135) [204:org.openhab.binding.rfxcom:2.3.
0]
at org.openhab.binding.rfxcom.handler.RFXComBridgeHandler$MessageListener.packetReceived(RFXComBridgeHandler.java:225) [204:org.openhab.binding.rfxcom
:2.3.0]
at org.openhab.binding.rfxcom.internal.connector.RFXComBaseConnector.sendMsgToListeners(RFXComBaseConnector.java:45) [204:org.openhab.binding.rfxcom:2
.3.0]
at org.openhab.binding.rfxcom.internal.connector.RFXComStreamReader.run(RFXComStreamReader.java:62) [204:org.openhab.binding.rfxcom:2.3.0]
Caused by: java.lang.reflect.InvocationTargetException
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method) ~[?:?]
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62) ~[?:?]
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45) ~[?:?]
at java.lang.reflect.Constructor.newInstance(Constructor.java:423) ~[?:?]
at org.openhab.binding.rfxcom.internal.messages.RFXComMessageFactory.createMessage(RFXComMessageFactory.java:130) ~[?:?]
... 3 more
Caused by: java.lang.UnsupportedOperationException
at org.openhab.binding.rfxcom.internal.messages.RFXComInterfaceControlMessage.<init>(RFXComInterfaceControlMessage.java:78) ~[?:?]
... 3 more
Nothing from the z-wave controller though. The controller is offline, but when I look at it under Control the counter for “OOF bytes received” is steadily increasing.
As I said, disconnecting these devices and reconnecting them (physically) solves the immediate problem… Where do I start looking?
EDIT: I moved the Z-wave controller back to its separate USB port and it is working fine for now.
