It works with the hue emulation.
You define with the [“Lighting”] in your Sitemap which Items should be detectable by Hue Emulation.
Then you enable Pairing Mode in Hue-Emulation.
Then you let Echo scan for Home Automation Devices (sometimes 2x)
Then Alexa finds your Items.
Then you disable Pairing Mode in Hue Emulation.
yes i can turn on my TV with the normal switch. I defined the hue emulation in the items file for my other items.
If i define it in the sitemap with [ “Switchable” ] the sitemap doesn´t even load in the browser.
How should i define [“Lighting”] in the sitemap? I don´t get it. It doesn´t work Every time i add [“Lighting”] in the sitemap definition the sitemap doesn´t load in the browser? Any ideas?
To expose an item on the service, apply a supported tag (which are “Lighting”, “Switchable”, “TargetTemperature”) to it. The item label will be used as the Hue device name.
