Hi all,
I am using “openHAB 2.0.0.b4 Build #477” and “Homegear version 0.6.7-1545” with the Homematic heater valve HM-CC-RT-DN. It works fine with all the standard items like SET_TEMPERATURE, ACTUAL_TEMPERATURE or VALVE_STATE.
Number HeatCtrl_TargetTemp "Temp. Soll [%.1f °C]" <temperature> (R1) { channel="homematic:HG-HM-CC-RT-DN:homegear:MEQ1234567:4#SET_TEMPERATURE" }
Number HeatCtrl_ActualTemp "Temp. Ist [%.1f °C]" <temperature> (R1) { channel="homematic:HG-HM-CC-RT-DN:homegear:MEQ1234567:4#ACTUAL_TEMPERATURE" }
Number HeatCtrl_ValveState "Ventilstellung [%d%%]" <heating> (R1) { channel="homematic:HG-HM-CC-RT-DN:homegear:MEQ1234567:4#VALVE_STATE" }
Now I would like to add the “heating plan values” like TEMPERATURE_SATURDAY_1 or TEMPERATURE_MONDAY_1. Homegear tells me that all these values are send via channel 0:
homegear -r
families select 0
peers list
peers select 1
config print
Channel: 0
[TEMPERATURE_WEDNESDAY_9]: 22
[TEMPERATURE_WEDNESDAY_7]: 22
[TEMPERATURE_WEDNESDAY_6]: 22
[TEMPERATURE_WEDNESDAY_5]: 22
[TEMPERATURE_WEDNESDAY_3]: 22
An item entry like
Number HeatCtrl_Temp_Wednesday "Temp. [%.1f °C]" <battery> (R1) { channel="homematic:HG-HM-CC-RT-DN:homegear:MEQ1234567:0#TEMPERATURE_WEDNESDAY_3" }
does not work. The openHAB log tells that a description could not be found for all the entries from channel 0.
2016-11-20 18:52:48.408 [INFO ] [binding.homematic.type.MetadataUtils] - Description not found for: MAINTENANCE|TEMPERATURE_WEDNESDAY_8, TEMPERATURE_WEDNESDAY_8
2016-11-20 18:52:48.410 [INFO ] [binding.homematic.type.MetadataUtils] - Description not found for: MAINTENANCE|I_VALUE_EXTERN, I_VALUE_EXTERN
2016-11-20 18:52:48.412 [INFO ] [binding.homematic.type.MetadataUtils] - Description not found for: MAINTENANCE|P_VALUE_INTERN, P_VALUE_INTERN
**2016-11-20 18:52:48.415 [INFO ] [binding.homematic.type.MetadataUtils] - Description not found for: MAINTENANCE|TEMPERATURE_WEDNESDAY_3, TEMPERATURE_WEDNESDAY_3**
2016-11-20 18:52:48.418 [INFO ] [binding.homematic.type.MetadataUtils] - Description not found for: MAINTENANCE|TEMPERATURE_WEDNESDAY_2, TEMPERATURE_WEDNESDAY_2
2016-11-20 18:52:48.420 [INFO ] [binding.homematic.type.MetadataUtils] - Description not found for: MAINTENANCE|TEMPERATURE_WEDNESDAY_1, TEMPERATURE_WEDNESDAY_1
2016-11-20 18:52:48.423 [INFO ] [binding.homematic.type.MetadataUtils] - Description not found for: MAINTENANCE|TEMPERATUREFALL_WINDOW_OPEN, TEMPERATUREFALL_WINDOW_OPEN
2016-11-20 18:52:48.426 [INFO ] [binding.homematic.type.MetadataUtils] - Description not found for: MAINTENANCE|TEMPERATURE_MONDAY_10, TEMPERATURE_MONDAY_10
2016-11-20 18:52:48.428 [INFO ] [binding.homematic.type.MetadataUtils] - Description not found for: MAINTENANCE|ENDTIME_WEDNESDAY_9, ENDTIME_WEDNESDAY_9
2016-11-20 18:52:48.430 [INFO ] [binding.homematic.type.MetadataUtils] - Description not found for: MAINTENANCE|ENDTIME_WEDNESDAY_8, ENDTIME_WEDNESDAY_8
2016-11-20 18:52:48.433 [INFO ] [binding.homematic.type.MetadataUtils] - Description not found for: MAINTENANCE|TEMPERATURE_MONDAY_13, TEMPERATURE_MONDAY_13
2016-11-20 18:52:48.436 [INFO ] [binding.homematic.type.MetadataUtils] - Description not found for: MAINTENANCE|TEMPERATUREFALL_WINDOW_OPEN_TIME_PERIOD, TEMPERATUREFALL_WINDOW_OPEN_TIME_PERIOD
What do I need to do so that the channel 0 values will work?
Thank you in advance.
Michael
