my items contain values similar to the first lines (15 and 20)
What I’m trying to achieve is some sort of settings page for my rooms, via my sitemap file that enables me to finetune the time for my pir sensors and the dimmer value for my dimmers.
Does anyone know if this is possible to achieve ? When I try to write it in rules it fails with 1:19:41.576 [ERROR] [.script.engine.ScriptExecutionThread] - Rule 'Badeværelse PIR timer': An error occurred during the script execution: Could not invoke method: org.joda.time.DateTime.plusMinutes(int) on instance: 2017-11-21T21:19:41.576+01:00
Well, beside the createTimer syntax you provide is wrong, what you have would probably work assuming that ctrl_led_nat is a Dimmer Item with a minor change.
lightTimer2 = createTimer(now.plusMinutes((ctrl_led_timer2.state as Number).intValue, [|
bad_rgbw_white.sendCommand(ctrl_led_nat.state)
Pay attention to the closing parens and brackets.
If that doesn’t work you can use:
bad_rgbw_white.sendCommand(ctrl_led_nat.state as PercentType)
Again, I’ll emphasize this assumes that ctrl_led_nat is a Dimmer Item. If it is not then more work needs to be done to convert whatever type it is into a PercentType.
Thanks a lot for the help. I’ll try and post the complete rule, perhaps it will make it more clear.
I’ve tried some different approaches to what you wrote in your earlier post, I had to change
bad_rgbw_white.sendCommand(ctrl_led_nat.state) ])
I got some errors regarding the parens
07:12:19.312 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'pir.rules' has errors, therefore ignoring it: [46,5]: missing ')' at 'lightTimer2'
So I added an extra ) I’ve tried with and without the .intValue
The error i get is as follows 07:11:05.361 [ERROR] [.script.engine.ScriptExecutionThread] - Rule 'Badeværelse PIR timer': An error occurred during the script execution: The name 'ctrl_led_timer1' cannot be resolved to an item or type.
My items file
Number ctrl_bad_timer1
Number ctrl_bad_timer2
Sitemap
Frame label=“Lys” {
Slider item=ctrl_bad_dag label="Dag niveau [%d %%]"
Slider item=ctrl_bad_nat label="Nat niveau [%d %%]"
Slider item=ctrl_bad_sove label="zZz niveau [%d %%]"
Setpoint item=ctrl_bad_timer1 label="Timer led [%.0f min.]"
Setpoint item=ctrl_bad_timer2 label=“Timer rum [%.0f min.]”
Here’s my full rule
var Timer lightTimer = null
var Timer lightTimer2 = null
rule "Badeværelse PIR timer"
Item bad_pir changed
// Cancel any existing timer1
if(lightTimer != null) {
lightTimer.cancel
lightTimer = null
// Cancel any existing timer2
if(lightTimer2 != null) {
lightTimer2.cancel
lightTimer2 = null
// turn on lights on movement
if(bad_pir.state == ON) {
// turn on day lights
if(ctrl_dag.state == ON) {
bad_rgbw_white.sendCommand(ctrl_bad_dag.state as PercentType)
else {
if(ctrl_sove.state == ON) {
// turn on sleep lights
bad_rgbw_white.sendCommand(ctrl_bad_sove.state as PercentType)
else {
// turn on night lights
bad_rgbw_white.sendCommand(ctrl_bad_nat.state as PercentType)
// Otherwise set a timer to turn off the light after defined minutes of no motion.
else {
// timer1 for led strip
lightTimer = createTimer(now.plusMinutes(ctrl_led_timer1.state as Number), [|
bad_rgbw_white.sendCommand(0)
// timer2 turning off room lights
lightTimer2 = createTimer(now.plusMinutes(ctrl_led_timer2.state as Number), [|
bad_loft.sendCommand(OFF)
bad_spejl.sendCommand(OFF)
