Use number in rules
Any one that can see whats wrong with this:
rule "Ladning af bil med solceller"
//	Time cron "0 0/5 * * * ?"		//hvert 5 min
//	Time cron "0 * * * * ?"			//hvert 1 min
	Time cron "0/10 * * ? * * *"	//hvert 10 sec
//	Time cron "0 0 * ? * * *"		//hver time
	if (Sun_car_power.state == ON){
		var String[] fase_123 = Easee_Circuit_Dynamic_Phases.state.toString.split(";")
		var Number amp_p3 = fase_123.get(2)
		var Number forbrug = el_forbrug_lige_nu.state.toString
		logInfo("bil-lader.rules", Easee_Circuit_Dynamic_Phases.state.toString)
		logInfo("bil-lader.rules", amp_p3)
		logInfo("bil-lader.rules", forbrug)
		if (Easee_Charger_Start_Stop.state == ON){
			if (forbrug < 0){
				Easee_Circuit_Dynamic_Phases.sendCommand(String::format("%d;%d;%s", 0, 0, amp_p3 + 1))
			if (forbrug > 100 && amp_p3 > 6){
				Easee_Circuit_Dynamic_Phases.sendCommand(String::format("%d;%d;%d", 0, 0, amp_p3 - 1))
			if (forbrug > 700 && amp_p3 == 6){
				Easee_Charger_Start_Stop.sendCommand(OFF)
		if (Easee_Charger_Start_Stop.state == OFF && forbrug < (-700)){
			Easee_Circuit_Dynamic_Phases.sendCommand(String::format("%d;%d;%d", 0, 0, 6))
			Easee_Charger_Start_Stop.sendCommand(ON)
Log:
2023-02-20 19:22:20.502 [INFO ] [ab.core.model.script.bil-lader.rules] - 0;0;11
2023-02-20 19:22:20.503 [INFO ] [ab.core.model.script.bil-lader.rules] - 11
2023-02-20 19:22:20.503 [INFO ] [ab.core.model.script.bil-lader.rules] - 489
2023-02-20 19:22:20.504 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID ‘bil-lader-2’ failed: An error occurred during the script execution: Could not invoke method: org.openhab.core.model.script.lib.NumberExtensions.operator_lessThan(java.lang.Number,java.lang.Number) on instance: null in bil-lader
Meanwhile, until an expert replies: you are assigning a string to a number variable.
Try:
var Number forbrug = el_forbrug_lige_nu.state as Number
Hi @Jakob
You are assigning a string here
and then you compare it with a Number
if (forbrug < 0){
Must fail. But don’t ask me why a Number declared variable changes to String by assignment :wink:
What is the datatype of “el_forbrug_lige_nu”. Perhaps you just have to delete “.toString”
As has been pointed out. A String is not a Number and you can’t do math with it as if it were a Number.
Rules DSL really wants to be weakly typed. Your life will go much better if you let it be weakly typed. And because it wants to be weakly typed, there is nothing that fixes the type or any variable. It will happily assign a String to a variable that was declared to be a Number.
The only times you should force a type in Rules DSL include:
  • you are initializing the variable to null: e.g. var Timer myTimer = null
  • you are casting because Rules DSL wasn’t able to determine the correct type on it’s own: e.g. (MyItem.state as Number)
  • it’s required to be a specific type, usually a primitive, for a call to a Java method: e.g. now.plusSeconds(mySecondsVariable.intValue)
In all other cases, forcing the type in Rules DSL will cause way more problems than it solves.
If I change it to
I will get an error on this line:
2023-02-20 20:48:00.808 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID ‘bil-lader-2’ failed: An error occurred during the script execution: Could not invoke method: org.openhab.core.model.script.actions.Log.logInfo(java.lang.String,java.lang.String,java.lang.Object[]) on instance: null in bil-lader
Any clue?
There is nothing on that line of code to tell logInfo that you want forbrug to be converted to a String. So call toString there.
I see, toString worked.
Now I get error on this line
2023-02-20 21:11:20.874 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID ‘bil-lader-2’ failed: An error occurred during the script execution: Could not invoke method: org.openhab.core.model.script.lib.NumberExtensions.operator_greaterThan(java.lang.Number,java.lang.Number) on instance: null in bil-lader
amp_p3 isn’t a Number either. It’s a String. You have to parse it into a Number to do math with it.
Again, see my reply above. var Number amp_p3 does not convert a String to a Number. For the most part, that does nothing. You have to parse a String into a Number.
All things considered, you’d have a much better time of this if you switched to Blockly.
Arh, now I see it.
Works if I change amp_p3 to Integer::parseInt(amp_p3)
Think you are right regarding the Blockly.
The downside is that I have many rules written in files since OpenHab 1.8
But in the future I will try Blockly
Thanks for your help :wink:
You can do it little by little. As you find you need to write new rules, choose Blockly for those. As you need to change rules, consider translating them to Blockly.
There’s no real harm in having a mix of .rules files and Blockly rules.
