It seems that this is working…
rule "Alle Stromzähler auslesen test2"
Item PowerMeter_new_test received update // String Item linked to exec:command channel that runs above script
var readings_lines = PowerMeter_new_test.state.toString.split('\n')
if ((readings_lines.size('\n') == 10) {
var test123_new = readings_lines.get(4).split('#').get(1)
PowerMeter_new1.postUpdate(test123_new)
How can i put the last two lines of the “if” into one single line?
