Use Timer in script?
Hi, trying to find an example of using a Timer in script.
What I want to do is execute several commands with a little delay.
I can do it in rules, but i want the code in a script so I can use it in multiple rules
my working rule:
import org.openhab.core.library.types.*
import org.openhab.core.persistence.*
import org.openhab.model.script.actions.*
import org.joda.time.*
var Timer timer
rule “rPoolOff”
Item Pool_Master changed from ON to OFF
sendCommand(Pool_Heating, OFF)
// wait until heater has cooled down
timer = createTimer(now.plusSeconds(60)) [|sendCommand(Pool_Circulation, OFF) ]
tnx in advance
You just need something like:
callScript(“automation_Active.script”)
in your THEN clause.
Script is:
var Number automationActiveDimmer
automationActiveDimmer=100
while(automationActiveDimmer > 0 {
    automationActiveDimmer=automationActiveDimmer-20
    sendCommand(di_LIGHT_LivingRoom_rf,automationActiveDimmer)
    Thread::sleep(2000)
You cannot feed arguments or environmental imports to the rule --- it has to be self-contained.
You mean you cannot feed arguments or environmental imports to the script.
OK
so “Thread::sleep(xxx)” is the right thing to use in scripts ?
tnx for the answers
/taisto
It should work in a script. If it doesn’t, try java.lang.Thread::sleep(xxx).
Thread::sleep(2000) Does work as originally posted.
