Is there a way to have a user configurable timer on any of the GUI/clients?
For instance if I wanted to give the user the ability to create a timer for switching a wall outlet or a lamp? An application might be that they might want to switch on a light at a certain time. Ideally they would maybe want to switch this on based on the local sunset (or using an offset of the sunset). Ideally, I would want the user to be able to define the timing to his liking, without having to go into a rule code and hardcoding the timer into a rule everytime they change their mind.
