Usiing MAP() for a part of a string
I assign the ntp date-time value to an Item ( copied from the demo)
DateTime Jetzt “Zeit [%1$tA, %1$td.%1$tm.%1$tY]” {ntp=“Europe/Berlin:de_DE”}
which nicely produces “Mittwoch, 12.13.14” in the browser UI, when done in openHab 1.8
with openHAB2, I discovered that the time format is created using English day names - even with de_DE specified, but I believed that a MAP would do the trick like
DateTime Jetzt “Zeit [MAP(de.map):%1$tA, %1$td.%1$tm.%1$tY]” {ntp=“Europe/Berlin:de_DE”}
in the items.cfg.
But it seems that I can not restrict the MAP-source-value to be that part “%1$tA” and leave the rest …
All examples of MAP I have found in internet, always add some “mapped” value at the end of the label string! Also I did not find any mentioning how to use 2 item values in ONE label string, maybe I did not search long enough.
Any help to sort that out is appreciated!
Hello, aren’t there any suggestions to the above question?
I get the same “problem”. I use the ntp-binding in openhab2, which works, but shows the day of the week in english instead of german!
Therefore I use a .map file (datum.map) in which I transform the days of the week from english to german. That really works, e.g. the day “Monday” ist now shown as “Montag”.
But now the problem: i would like the date and the time follows in one row. Like this:
Text item=DatumZeit label="[MAP(datum.map):%1$tA]" (and now date an time to follow).
This shows (e.g.) Montag. But now i like to follow “%1$td, %1$™, %$1tY” but this does not work!
How can i do that, is it possible?
Best regards.
PJH
I have my item defined as follows:
DateTime  CurrDateTime    "Datum [%1$tA, %1$td.%1$tm.%1$tY]"                        <clock>       (Astro) { channel="ntp:ntp:local:dateTime" }
But with
EXTRA_JAVA_OPTS="-Duser.language=de -Duser.country=DE"
in /etc/default/openhab2
Hello, where can i find it in ElCapitan, there is no such directory?
Thank you. Best regards. PJH
Sorry, I don’t know anything about the folder layout on Mac OS
