I would like to use a knob widget to set a timer.
But unfortunately I do not manage to set the format to a duration like H:mm:ss.
It would be also great if the scale could be set logarithmic.
Is the a solution for the two points?
Regards
You could make the knob widget just to set the seconds or minutes in a day.
A day has 1440 minutes (0 to 1439) You set the minute and with a script
you can transform it to time.
This is my num2time.js
(function(i) {
if (input >= 0 && input <= 1439) {
var hr = Math.floor(input / 60);
var min = input - hr * 60;
return (hr < 10 ? "0" : "") + hr + ":" + (min < 10 ? "0" : "") + min;
} else {
return input;
})(input);
Thank you @Charley.
But the Value in the middle of the knob would be then not the timer setting. Right?
No it will show the minute of the day like 17:49 = 1069
I use it in rules that run a lot
You can use a dummy below/above the knob to show the Time value
@Charley Thank you for your ideas. That way I will make it work even though having the set time in the middle of the knob would be even better.
But now I am struggling with using the knob in a costume widget. It just does not want to work:
<div ng-init="knobmodel1=
"name": "Timerxy",
"sizeX": 3,
"sizeY": 3,
"item": "timer1",
"type": "knob",
"row": 1,
"col": 0,
"floor": 0,
"ceil": 180,
"step": 1,
"unit": "",
"format": "",
"useserverformat": false,
"barWidth": 30,
"trackWidth": 30,
"scaleEnabled": true,
"scaleType": "dots",
"scaleSpaceWidth": null,
"skinType": "tron",
"ranges": [
"min": 0,
"max": 60,
"barColor": "#66FFFF"
"min": 60,
"max": 120,
"barColor": "#33CCFF"
"min": 120,
"max": 180,
"barColor": "#0099FF"
"scaleColor": "#66FFFF",
"scaleQuantity": 18,
"rangesEnabled": true,
"rangesTextColorMatching": true,
"readOnly": false
<widget-knob ng-model="knobmodel1"></widget-knob>
