I’m having trouble with adding an openhab group item to settings in a template
I have the following group defined
Group items_id_gClimates
String climate0 "[%s]" (items_id_gClimates) { ecobee="<[000000000000#program.climates[0].climateRef]" }
String climate1 "[%s]" (items_id_gClimates) { ecobee="<[000000000000#program.climates[1].climateRef]" }
String climate2 "[%s]" (items_id_gClimates) { ecobee="<[000000000000#program.climates[2].climateRef]" }
Then i have a widget where i defined a setting
Type: Item
Default value: items_id_gClimates
My code
<table><tr><td><ul>
<li>Using Setting length = {{(itemsInGroup('config.habpanel_id_climates')).length}}</li>
<li>Using item directly = {{(itemsInGroup('items_id_gClimates')).length}}</li>
</ul></td></tr></table>
The result i get is :
Using Setting length = 0
Using item directly = 3
I’m expecting both to be 3
I have tested with non-group-item settings and those I can get to work, what am I doing wrong?
