Using MQTT binding jar in IDE fails
I run openHAB 2 from the IDE in order to develop and test some bindings. I still want to use the MQTT binding and a few others. Today, the MQTT binding stopped working. I am using the bindings from the Addons download kar file.
org.openhab.binding.mqtt-1.10.0.jar
org.openhab.io.transport.mqtt-1.10.0.jar
I’ve put them in a directory and included it on the target platform. The binding starts up and reads its configuration, but just before loading the items file, I get the monster of a stack trace below. I try to keep the openhab-distro and openhab2-addons repos up to date, and keep my target platform and launch configuration close to the current version. I don’t know if this is a bug or just a product of my unusual setup. Any help appreciated. I also included a log file. It’s not XML, but the forum wouldn’t let me upload txt. log.xml (564.2 KB)
!ENTRY org.eclipse.smarthome.model.item 4 0 2017-10-17 22:30:25.827
!MESSAGE [org.eclipse.smarthome.model.item.provider(1)] The addItemFactory method has thrown an exception
!STACK 0
java.lang.AbstractMethodError: org.openhab.core.binding.internal.BindingConfigReaderDelegate.processBindingConfiguration(Ljava/lang/String;Ljava/lang/String;Ljava/lang/String;Ljava/lang/String;Lorg/eclipse/smarthome/config/core/Configuration;)V
at org.eclipse.smarthome.model.item.internal.GenericItemProvider.internalDispatchBindings(GenericItemProvider.java:335)
at org.eclipse.smarthome.model.item.internal.GenericItemProvider.dispatchBindingsPerItemType(GenericItemProvider.java:263)
at org.eclipse.smarthome.model.item.internal.GenericItemProvider.addItemFactory(GenericItemProvider.java:110)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.apache.felix.scr.impl.inject.BaseMethod.invokeMethod(BaseMethod.java:229)
at org.apache.felix.scr.impl.inject.BaseMethod.access$500(BaseMethod.java:39)
at org.apache.felix.scr.impl.inject.BaseMethod$Resolved.invoke(BaseMethod.java:650)
at org.apache.felix.scr.impl.inject.BaseMethod.invoke(BaseMethod.java:506)
at org.apache.felix.scr.impl.inject.BindMethod.invoke(BindMethod.java:658)
at org.apache.felix.scr.impl.manager.DependencyManager.doInvokeBindMethod(DependencyManager.java:1722)
at org.apache.felix.scr.impl.manager.DependencyManager.open(DependencyManager.java:1556)
at org.apache.felix.scr.impl.manager.SingleComponentManager.createImplementationObject(SingleComponentManager.java:261)
at org.apache.felix.scr.impl.manager.SingleComponentManager.createComponent(SingleComponentManager.java:109)
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:906)
at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:879)
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:823)
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$1.run(ServiceFactoryUse.java:212)
at java.security.AccessController.doPrivileged(Native Method)
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:210)
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:111)
at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:45)
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:508)
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:461)
at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:624)
at org.apache.felix.scr.impl.manager.SingleRefPair.getServiceObject(SingleRefPair.java:72)
at org.apache.felix.scr.impl.inject.BindMethod.getServiceObject(BindMethod.java:651)
at org.apache.felix.scr.impl.manager.DependencyManager.getServiceObject(DependencyManager.java:2201)
at org.apache.felix.scr.impl.manager.DependencyManager.doInvokeBindMethod(DependencyManager.java:1714)
at org.apache.felix.scr.impl.manager.DependencyManager.invokeBindMethod(DependencyManager.java:1699)
at org.apache.felix.scr.impl.manager.SingleComponentManager.invokeBindMethod(SingleComponentManager.java:372)
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:320)
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:291)
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1215)
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1136)
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:945)
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:881)
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1167)
at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:127)
at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109)
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:920)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862)
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801)
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:127)
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:225)
at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:469)
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:887)
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:874)
at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:132)
at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:941)
at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:741)
at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.addedService(DependencyManager.java:1012)
at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.addedService(DependencyManager.java:968)
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:675)
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:430)
at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:657)
at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:341)
at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:390)
at org.apache.felix.scr.impl.Activator.access$200(Activator.java:54)
at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:265)
at org.apache.felix.utils.extender.AbstractExtender.createExtension(AbstractExtender.java:254)
at org.apache.felix.utils.extender.AbstractExtender.modifiedBundle(AbstractExtender.java:227)
at org.apache.felix.utils.extender.AbstractExtender.addingBundle(AbstractExtender.java:187)
at org.osgi.util.tracker.BundleTracker$Tracked.customizerAdding(BundleTracker.java:469)
at org.osgi.util.tracker.BundleTracker$Tracked.customizerAdding(BundleTracker.java:1)
at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256)
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:229)
at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444)
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:908)
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213)
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120)
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112)
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:168)
at org.eclipse.osgi.container.Module.publishEvent(Module.java:476)
at org.eclipse.osgi.container.Module.doStart(Module.java:578)
at org.eclipse.osgi.container.Module.start(Module.java:449)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1628)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1608)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1579)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1522)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
Well that’s a pretty worthless error message, isn’t it?
But I think it’s just failing to parse one of your item bindings properly. So maybe start by verifying those are ok.
Yeah, maybe the error is not useful. I was wondering if someone had just changed org.openhab.core.binding.internal.BindingConfigReaderDelegate.processBindingConfiguration into an abstract method in the framework. I’ll double check my item files and also try to reproduce it in a clean IDE…
It also fails with a fresh installed IDE, and a minimal configuration:
items/mqtt.items
Switch sovLys1paa "Test" {mqtt=">[mygg:soverom/lys/1/paa:command:*:default]"}
sitemaps/fas.sitemap (not actually needed)
sitemap fas label="Fas"
    Frame label="Annet" {
        Switch item=sovLys1paa
services/runtime.cfg
mqtt:mygg.url=tcp://192.168.1.2:1883
mqtt:mygg.clientId=electron
output.not.xml (95.1 KB)
It works if I check out the openhab-core repo and use the compat1x project from there, instead of the one from the target platform. Seems to be some incompatibility that will be solved in a proper release. Anyway, things are good, I don’t have to get on the phone every time I need the lights at night :slight_smile:
