Guys, Is it possible to merge this code that i got from https://github.com/OLIMEX/ESP8266 with the one that @robb01published to read the temperature? I want to have a NodeMCU that can read the temperature and switch a relay on the same device. What should i move? Thank you for your help.
* This code switches a relay connected to port 5 (GPIO5) on an ESP8266.
* It will connect to MQTT and listens on topic house/2/attic/cv/thermostat/relay
* for 'on' and 'off' commands. Every 60 seconds, it will publishes te current
* state on house/2/attic/cv/thermostat/relay_state
* Dimitar Manovski
* support@smart-republic.com
#include <ESP8266WiFi.h>
#include <PubSubClient.h>
int RelayPin = 5; // RELAY connected to digital pin 5
const char* ssid = "comhem_D64E3F";
const char* password = "b7at87t6";
//change with your MQTT server IP address
const char* mqtt_server = "192.168.0.10";
WiFiClient espClient;
PubSubClient client(espClient);
void callback(char* topic, byte* payload, unsigned int length) {
Serial.print(topic);
Serial.print(" => ");
char* payload_str;
payload_str = (char*) malloc(length + 1);
memcpy(payload_str, payload, length);
payload_str[length] = '\0';
Serial.println(String(payload_str));
if ( String(topic) == "house/2/attic/cv/thermostat/relay" ) {
if (String(payload_str) == "on" ) {
digitalWrite(RelayPin, HIGH); // turn the RELAY on
client.publish("house/2/attic/cv/thermostat/relay_state","on");
} else if ( String(payload_str) == "off" ) {
digitalWrite(RelayPin, LOW); // turn the RELAY off
client.publish("house/2/attic/cv/thermostat/relay_state","off");
} else {
Serial.print("I do not know what to do with ");
Serial.print(String(payload_str));
Serial.print(" on topic ");
Serial.println( String(topic));
void connect_to_MQTT() {
client.setServer(mqtt_server, 1883);
client.setCallback(callback);
if (client.connect("thermostat_relay")) {
Serial.println("(re)-connected to MQTT");
client.subscribe("house/2/attic/cv/thermostat/relay");
} else {
Serial.println("Could not connect to MQTT");
void setup() {
Serial.begin(115200);
delay(10);
// Connecting to our WiFi network
Serial.println();
Serial.println();
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, password);
while (WiFi.status() != WL_CONNECTED) {
delay(500);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
Serial.println("IP address: ");
Serial.println(WiFi.localIP());
connect_to_MQTT();
// initialize pin 5, where the relay is connected to.
pinMode(RelayPin, OUTPUT);
int tellstate = 0;
void loop() {
client.loop();
if (! client.connected()) {
Serial.println("Not connected to MQTT....");
connect_to_MQTT();
delay(5000);
// Tell the current state every 60 seconds
if ( (millis() - tellstate) > 60000 ) {
if ( digitalRead(RelayPin) ) {
} else {
tellstate = millis();
