I’m updating some items via REST-API and the logfile is now spammed with entries like:
2020-05-25 12:40:19.777 [ome.event.ItemCommandEvent] - Item 'WeatherBinder_softwaretype' received command EasyWeatherV1.4.9
2020-05-25 12:40:19.785 [ome.event.ItemCommandEvent] - Item 'WeatherBinder_action' received command updateraw
2020-05-25 12:40:19.793 [ome.event.ItemCommandEvent] - Item 'WeatherBinder_realtime' received command 1
2020-05-25 12:40:19.800 [ome.event.ItemCommandEvent] - Item 'WeatherBinder_rtfreq' received command 5
2020-05-25 12:40:19.717 [vent.ItemStateChangedEvent] - WeatherBinder_absbaro changed from 976.58 hPa to 976.48 hPa
2020-05-25 12:40:19.718 [ome.event.ItemCommandEvent] - Item 'WeatherBinder_rain' received command 0
2020-05-25 12:40:19.732 [ome.event.ItemCommandEvent] - Item 'WeatherBinder_dailyrain' received command 0
2020-05-25 12:40:19.735 [GroupItemStateChangedEvent] - gWeatherPressure changed from 1004.93 to 1004.88 through WeatherBinder_baro
2020-05-25 12:40:19.737 [ome.event.ItemCommandEvent] - Item 'WeatherBinder_weeklyrain' received command 0.03
Can I do something to avoid the “received command” entries, which send the same value as the item already has? Updating via (legacy v1) mqqt-eventbus only sends the “item changed from to”-entries…
