I need help.
Since one hour, I am trying to use the REST documentation from my dev environment.
After starting my server, I have an access to the REST API (swagger) but as soon as I try to GET bindings or services for example, I got a 404 error.
If I try the following URL in my browser, I got the same 404 error: http://192.168.x.xxx:8080/services
HTTP ERROR 404
Problem accessing /services. Reason:
ProxyServlet: /services
I don’t understand what bundles are missing in my RUN configuration.
You’re right, I did not realize that /rest was missing in the URL !
The problem is that the REST documentation started from Eclipse is not including /rest in the URL while of course it does in my production environment.
Of course, http://192.168.xx.xxx:8080/rest/services is working well in my dev env.
Any idea why the URLs are wrong ?
