Using the profile "follow", avoiding loops?
Tags: #<Tag:0x00007f2fc0437f00> #<Tag:0x00007f2fc0437cf8>
Hi Guys,
would like to use the profilefollow”.
I have e.g. two items:
itemA and itemB.
I would like itemB to follow itemA, but also itemA to follow itemB.
Will this create a loop? Or is that impossible?
The description here says that the FollowProfile ignores state updates.
here is the syntax:
<itemType> <itemName> {channel = "<channelUID>", channel = "<followChannelUID>" [profile = "follow"]}
Example:
Switch itemA {channel="xxxx.of.itemA", channel="xxxx.of.itemB" [profile="follow"]}
Switch itemB {channel="xxxx.of.itemB", channel="xxxx.of.itemA" [profile="follow"]}
I could try on my own, but I’m afraid of an overflowing logfile or something else.
You should just try it out. If OH ends up in a look, just kill OH, back out the follow, and start OH again.
I suspect it will work just fine.
I did it. It is running. :slight_smile: No loop!
Example:
