Is it possible to use the Speaker Endpoint to start playing Spotify via an Alexa command on this Item? The reason why I would like to do this, my Denon Heos speaker has not yet a full Spotify-integration, but when using the Spotify Connect Binding I can still access and control it. So the idea would be to create a new Speaker Endpoint in Openhab and internally control it via Spotify Connect.
Unfortunately, I couldn’t find in the Speaker endpoint documentation any link to the source that’s set via an Alexa command. There’s an InputController and a ChannelController, but also when checking the offical Alexa documentation Spotify is not a viable option on these.
Did anyone use yet the Speaker Endpoint, set it as default Speaker for Alexa and then select Spotify on it?
Best,
Tobias.
