Using uppercase letter for group item (capital letter)
Hi all,
It took me at least 2 hours to find out that the group switch did not work with uppercase letter for item names.
This works:
Switch Licht_KG_Flur	"Licht Flur & Treppe"		(KG_Flur, Licht, gTestKeller)	[ "Lighting" ]	{knx="1/2/1"}
Switch Licht_KG_HWR	"Licht HWR"			(KG_HWR,  Licht, gTestKeller)	[ "Lighting" ]	{knx="1/2/6"}
Group:Switch:OR(ON, OFF) gTestKeller  "Test Gruppe Licht Keller [(%d)]"  <light>
This doesn´t work
Switch Licht_KG_Flur	"Licht Flur & Treppe"		(KG_Flur, Licht, TestKeller)	[ "Lighting" ]	{knx="1/2/1"}
Switch Licht_KG_HWR	"Licht HWR"			(KG_HWR,  Licht, TestKeller)	[ "Lighting" ]	{knx="1/2/6"}
Group:Switch:OR(ON, OFF) TestKeller  "Test Gruppe Licht Keller [(%d)]"  <light>
Is this limitation only valid here? or on other sections too?
Best regards
Timo
