I’m using influxdb for persistence. Ever since I started using influxdb which is a few months ago I’ve had the following entries in the log:
[ERROR] [ntime.internal.engine.ExecuteRuleJob] - Error during the execution of rule 'ut': {"error":"error authorizing query: openhab not authorized to execute statement 'SELECT value FROM autogen.Weather_Temperature WHERE time \u003e 17551d LIMIT 2147483647', requires READ on openhab"}
The ‘ut’ rule is basically the default rule which works out the minimum and maximum temperatures for the day. The rule itself is below
rule “ut”
Item Weather_Temperature changed or
Time cron “0 0 0 * * ?” or
System started
postUpdate(Weather_Temp_Max, Weather_Temperature.maximumSince(now.withTimeAtStartOfDay).state)
postUpdate(Weather_Temp_Min, Weather_Temperature.minimumSince(now.withTimeAtStartOfDay).state)
How can I fix this?
