Is there any example how to use MqttService in OpenHAB2 AddOn development?
I am able to use Declarative Service to pass MqttService to my newly developed AddOn package. However, I am not able to publish any message. Here are some of the codes i use. After i register the producer, the senderChannel remains null, is this normal? Or i have to manually instantiante an MqttSenderChannel and push it to “publisher” before sending a message? Thanks
//MqttMessagePublisher is a new implementation class for MqttMessageProducer
publisher = new MqttMessagePublisher(parentHandler.gatewayConfig.broker, deviceConfig.mqttTopic);
mqttservice.registerMessageProducer(parentHandler.gatewayConfig.broker, publisher);
publisher.publish(deviceConfig.mqttTopic, "test".getBytes());
[Update] Again, looks like i solved it faster than response
It turns out that I need to pass the .cfg configurations into MQTTService Declarative Service. For those that is interested (i am not sure whether this is a right approach, but it works) this is my XML file in OSGI-INF:
As mentioned in Retrieve settings from /services/xxx.cfg, you should not use ManagedService, but rather have the configuration injected into the activate method.
