Folks,
I have 2.4 running on an RPi (Not Habian)
I want to move and upgrade to a different RPi an docker.
- I create a new container with 2.5 and start it.
- I can see the web UI and follow the tutorial, install the default UIs
- I exec into the container and run a restore from my 2.4 backup zip.
- I restart the container.
I get nothing.
- I see the runtime.cfg is not updated and shows the karaf binding is still 127.0.0.1 and commented out.
- I see there are still references to āorg.eclipse.smarthomeā. I thought this was supposed to be removed (the eclipse part)?
- I get the following in the log files
2019-12-16 20:30:08.856 [WARN ] [org.apache.felix.fileinstall ] - /usr/share/openhab2/addons does not exist, please create it.
2019-12-16 20:30:08.955 [ERROR] [org.apache.felix.fileinstall ] - Cannot create folder /var/lib/openhab2/tmp/bundles. Is the folder write-protected?
2019-12-16 20:30:08.956 [ERROR] [org.apache.felix.configadmin ] - [org.osgi.service.cm.ManagedServiceFactory, id=39, bundle=10/mvn:org.apache.felix/org.apache.felix.fileinstall/3.6.4]: Unexpected problem updating configuration org.apache.felix.fileinstall.80a2cfbd-b3be-483c-bb41-59dbce24ca5e
java.lang.RuntimeException: Cannot create folder: /var/lib/openhab2/tmp/bundles
at org.apache.felix.fileinstall.internal.DirectoryWatcher.prepareDir(DirectoryWatcher.java:647) ~[?:?]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.prepareTempDir(DirectoryWatcher.java:627) ~[?:?]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.<init>(DirectoryWatcher.java:179) ~[?:?]
at org.apache.felix.fileinstall.internal.FileInstall.updated(FileInstall.java:248) ~[?:?]
at org.apache.felix.fileinstall.internal.FileInstall$ConfigAdminSupport$Tracker.updated(FileInstall.java:378) ~[?:?]
at org.apache.felix.cm.impl.helper.ManagedServiceFactoryTracker.updated(ManagedServiceFactoryTracker.java:159) ~[bundleFile:?]
at org.apache.felix.cm.impl.helper.ManagedServiceFactoryTracker.provideConfiguration(ManagedServiceFactoryTracker.java:93) [bundleFile:?]
at org.apache.felix.cm.impl.ConfigurationManager$ManagedServiceFactoryUpdate.provide(ConfigurationManager.java:1253) [bundleFile:?]
at org.apache.felix.cm.impl.ConfigurationManager$ManagedServiceFactoryUpdate.run(ConfigurationManager.java:1197) [bundleFile:?]
at org.apache.felix.cm.impl.UpdateThread.run0(UpdateThread.java:138) [bundleFile:?]
at org.apache.felix.cm.impl.UpdateThread.run(UpdateThread.java:105) [bundleFile:?]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_232]
2019-12-16 20:31:43.961 [WARN ] [org.apache.felix.fileinstall ] - /usr/share/openhab2/addons does not exist, please create it.
2019-12-16 20:31:44.045 [ERROR] [org.apache.felix.fileinstall ] - Cannot create folder /var/lib/openhab2/tmp/bundles. Is the folder write-protected?
2019-12-16 20:31:44.046 [ERROR] [org.apache.felix.configadmin ] - [org.osgi.service.cm.ManagedServiceFactory, id=39, bundle=10/mvn:org.apache.felix/org.apache.felix.fileinstall/3.6.4]: Unexpected problem updating configuration org.apache.felix.fileinstall.80a2cfbd-b3be-483c-bb41-59dbce24ca5e
2019-12-16 20:34:19.444 [WARN ] [org.apache.karaf.main.Main ] - Lock lost. Setting startlevel to 1
2019-12-16 20:34:20.877 [WARN ] [org.apache.felix.fileinstall ] - /usr/share/openhab2/addons does not exist, please create it.
2019-12-16 20:34:20.878 [ERROR] [org.apache.felix.fileinstall ] - Cannot create folder /var/lib/openhab2/tmp/bundles. Is the folder write-protected?
2019-12-16 20:34:20.879 [ERROR] [org.apache.felix.configadmin ] - [org.osgi.service.cm.ManagedServiceFactory, id=68, bundle=10/mvn:org.apache.felix/org.apache.felix.fileinstall/3.6.4]: Unexpected problem updating configuration org.apache.felix.fileinstall.80a2cfbd-b3be-483c-bb41-59dbce24ca5e
2019-12-16 20:34:22.101 [WARN ] [org.apache.karaf.main.Main ] - Lock lost. Setting startlevel to 1
2019-12-16 20:34:31.271 [WARN ] [org.apache.felix.fileinstall ] - /usr/share/openhab2/addons does not exist, please create it.
2019-12-16 20:34:31.273 [ERROR] [org.apache.felix.fileinstall ] - Cannot create folder /var/lib/openhab2/tmp/bundles. Is the folder write-protected?
2019-12-16 20:34:31.273 [ERROR] [org.apache.felix.configadmin ] - [org.osgi.service.cm.ManagedServiceFactory, id=97, bundle=10/mvn:org.apache.felix/org.apache.felix.fileinstall/3.6.4]: Unexpected problem updating configuration org.apache.felix.fileinstall.80a2cfbd-b3be-483c-bb41-59dbce24ca5e
2019-12-16 20:34:46.737 [WARN ] [org.apache.felix.fileinstall ] - /usr/share/openhab2/addons does not exist, please create it.
2019-12-16 20:34:46.751 [ERROR] [org.apache.felix.fileinstall ] - Cannot create folder /var/lib/openhab2/tmp/bundles. Is the folder write-protected?
2019-12-16 20:34:46.752 [ERROR] [org.apache.felix.configadmin ] - [org.osgi.service.cm.ManagedServiceFactory, id=39, bundle=10/mvn:org.apache.felix/org.apache.felix.fileinstall/3.6.4]: Unexpected problem updating configuration org.apache.felix.fileinstall.80a2cfbd-b3be-483c-bb41-59dbce24ca5e
Should this method have worked for the upgrade path?
Should I rather upgrade in-situ and then migrate to docker?
C
