Just changed back to snapshot and noticed a new message in the log:
[INFO ] [el.core.internal.ModelRepositoryImpl] - Validation issues found in configuration model ‘default.sitemap’, using it anyway:
Linkable widget should contain either only frames or none at all
This is the portion of my sitemap that has been identified as being related, i.e. Frame under Group :
Group item= UPS label= "UPS" icon="energy" {
Text item= Ups_Model
Text item= Ups_Input_Voltage
Text item= Ups_Output_Voltage
Text item= Ups_Load
Text item= Ups_Runtime
Text item= Ups_Status
Frame label= "AC voltage" {
Chart item= Ups_Input_Voltage period=D refresh=30000
Should I leave this as it is and ignore the message or any change is required?
