I’m working on my first binding to get Mopidy controls to openhab. I’ve installed eclipse and set up the environment following the instructions so it seems to work okish, meaning I have the binding running and I can discover the Mopidy service from my local network. However, the run configuration does not start any ui, no paper ui nor anything else (can access the rest api thou) and this makes the testing and developing a bit cumbersome.
There are a few validation issues at startup, which point to paper ui for example. I’m wondering is this normal and I have just missed something, or should I just reinstall the environment and it should work better
Any help would be appreciated to get the coding faster.
