Griesi
(Markus)
March 17, 2017, 5:25pm
1
I like to send after change (switch) my curent value + 1.
How I have to create my rule?
rule "Lauter PLUS"
Item OnkyoPlus received update
onkyoVolume1 = onkyoVolume1 + 1
Dimmer onkyoVolume1 “Lautstärke [%d]” (Onkyo) {onkyo=“INIT:Musik:VOLUME_QUERY, INCREASE:Musik:VOLUME_UP, DECREASE:Musik:VOLUME_DOWN, *:Musik:VOLUME_SET”, knx=“0/6/4”}
Switch OnkyoMinus “Lautstärke Plus” (gHidden) { knx=“0/6/8” }
Switch OnkyoPlus “Lautstärke Minus” (gHidden) { knx=“0/6/9” }
Background: controll via KNX controller
Oli
(Oliver Stenzel)
March 17, 2017, 5:41pm
2
Shouldn’t
sendCommand(onkyoVolume1,VOLUME_UP)
do the trick?
Griesi
(Markus)
March 17, 2017, 6:35pm
3
was not successful …any other idee?
Oli
(Oliver Stenzel)
March 17, 2017, 6:44pm
4
if you look in events.log, what command gets sent when you press the Dimmer item?
if you send this command in the rule it should work…
Shouldn’t be
sendCommand(onkyoVolume1,INCREASE)
Griesi
(Markus)
March 18, 2017, 1:41pm
6
is not working - how I can use the current voume no. + 1?
Oli
(Oliver Stenzel)
March 18, 2017, 2:11pm
7
var Number TheVolume= (onkyoVolume1.state as DecimalType)+1
sendCommand(onkyoVolume1,TheVolume)
Dimmer Items take values from 0 to 100, so adding 1 will not make much of a difference. Play with the value.
Also you need to make sure that the values you send to not go below 0 or above 100.
Griesi
(Markus)
March 21, 2017, 7:05pm
8
Thanks a lot! It works great
